Hey Gang: I've always loved the Larger JDM Wind Deflector look on a VX but since they hard to come by here in the U.S ( Except for JohnnyApollo,lol) I've been doing some searching and AVS Makes an Off-Road model that offers 5" of vent shielding (at least on the model I used). I also have been doing some "Car Lot" cruising/test fitting using my "WeatherTech" deflector and have came up with one close that kinda follows the VX door-line. But it is longer and had to be cut and also trimmed by the mirror as seen in the pic's. For now it is open at the top rear but I have it extending some to leave room to work with it in case I close it in, but I might leave it because it is very solid and the 3M tape is killer, the visor material is thicker and very very solid. Also they are darker so there is a growing blind-spot ( I've only driven around town acouple days with them, and it's not as bad as I thought it would be) Anyway I'll update as I continue and Let you know the model # of the one I use once I feel good about the fit/finish
gonna try and glue it together this weekend but if not i will cut it down to make it look as normal as possible. What did you use to trim yours with??
