It's driving me mad! I think the only thing I can do to sort it is remove the passenger airbag. Has anybody done this or got any tips?
Thanks
Nick![]()
Thanks
Nick![]()
Take out your stereo i think you can get behind it abit.
Not 100% sure tho :S
I had a dash rattle ended being a random screw sitting in a hole. right behind my gauges.
Edit
Ignore about the stereo i just checked a pic of mine doesnt look like it all what was i thinking! XD
if you do remove the airbag---> DO NOT unplug any 'yellow' harness or plug with the ignition turned on (likewise if you turn the ignition on after you unplug a 'yellow' plug, you will be sorry, you must first get all 'yellow' plugs back into place before the ignition is replugged)
you can reach a lot of behind the airbag if you remove your glove box and some of the plastic air conditioning boxes behind it. maybe try removing the glove box first...
