Results 1 to 5 of 5
Thread: Squeaking noise when I drive.. Shocks??
    2001, Ebony, VX, 1458
    I am hearing a squeaking noise when drive. It seems like it is the front shocks. Does this mean its time to change them? Has anyone else experienced this? Any suggestions or fixes?
    Chet - CBA_VX
    Since it seems that a lot of people are posting that silicone spray is a universal cure-all for squeeks and anything rubber related on the VX , I'd recommend that you try using it to isolate the location of the squeek starting with the sway bar bushings then the shock mount bushings then spray some on ALL the hood bumpers(rear of hood also). Do one area at a time, then drive it to see if squeek is reduced or eliminated . Once you isolate the problem area, you can repair or replace.
    Keep the silicone away from the brake rotors!
    1999 White Ironman 0046
    Is it at all possible that the squeek could be coming from the hood latch? That's what always squeeks on mine.
    Return evil for evil to no one...as far as it depends upon YOU, be peaceable with all men. Romans 12:17, 18
    Apr 2003
    2001, Ebony, 0761
    Squeek
    I had a squeek coming from the front hood rubber stops. By raising them a half twist, the squeek stopped. That was 10 months ago and it is still quiet. I hope this helps.
    Howard
    It worth trying!
    That might be it. Since the squeaking started after I got my VX back from the repair shop.
    Two cars collided at an intersection and rammed into my parked VX pushing me into the car parked ahead of me. So I had had damage to the front.
    I'll take a look today. Thanks!
  1. Squeaking...tachometer?
    By Breezy in forum VX Troubleshooting...
    Last Post: 09/22/2011, 11:47 AM
  2. Belt Drive Pulley Noise?
    By Kenny in forum VX Troubleshooting...
    Last Post: 05/09/2005, 12:06 PM
  3. The Squeaking Is Drivng Me Crazy!!
    By Panther_Black_VX in forum VX Troubleshooting...
    Last Post: 10/03/2003, 10:47 AM
  4. Drive train noise
    By PBR in forum VX Talk...
    Last Post: 04/28/2003, 10:34 PM
  5. Drive train noise
    By PBR in forum VX Troubleshooting...
    Last Post: 03/25/2003, 07:24 PM
