Originally Posted by
CowboyErik
last time I filled my tranny, it took 1.75 gallons of ATF fluid, sound about right? I used air to purge intercooler and my pans have been dripping for several days, got lots out
Joe Blacks write up used about 7.5 quarts, so this is pretty close but may be a bit low.
Just make sure that after the initial fill you start it up, run it through all of the gears, and check the level to make sure it's full. If you do that you can't go wrong with the refill.
