yep, took some video last night , Will up load it now.
HERE, there's noise from the passenger hub and the front diff. Also if i rotate the rear propshaft there is a noise coming from the back of the transpher case and possibly the gearbox.
http://www.youtube.com/watch?v=1B914U8eTIk
It's possibly a mix of two or three things! If you hold the wheel, do you have any play on the driveshaft either rotationally or in and out? The play and noise does sound like UJ's. Have you checked them? And the needle bearing could still be to blame?
Nick![]()
Also, on the offchance, have you seen this thread.... http://www.vehicross.info/forums/showthread.php?t=9674
Nick
The more i listen to this noise (twice a day) the more it sounds like a rock touching a propshat, you know a kinda lathe noise ???? Maybe something is loose and theres movement in the tranny causing it to hit something but i did have a good look round. There is movement in the transher case lever but not alot on accelleration arghhhhhhhhhhh
Damn, I was hoping to find you'd sussed this
I can't even suggest anything else and I'd say Nick knows way more than me!
A
DOH Nightmare
Also, i just checked the gear box fluid and there's way too much. Dont really know how to find the problem
James, if you wanna come down over the weekend, we can have looksie together? I'm out Saturday, but free Friday, Sunday and Monday.
Nick![]()
Thansk mate, very kind of you. However Its sorted![]()
Finally got to my Dads place in the workshop and turned out to be a bent up skit plate vibrating on the exhaust under tourque. Thank frig for that !!!!!
LOL! Thats a result then! Cool!
Nick
Phew! Nice to see someone with a skid pan more mangled than mine too...
A
