Results 1 to 4 of 4
Thread: TOD indicator check light on
    Jul 2009
    1998 Silver Vehicross
    Angry TOD indicator check light on
    some help here. i have a 98 model VCross and all is ok when my 4wd lever is on TOD or L4wd. but when i put it on 2wd after 5 mins of driving the check indicator light starts flashing. when i put it back to TOD it goes off. any ideas anybody.
    Jan 2008
    1999 Astral Silver 0481
    Quote Originally Posted by anit View Post
    Hi Anit !
    Did you feel any difference in the way the VX is performing when you go 2WD ?
    Check all T-case connectors & wiring.
    Also make sure all tires are properly inflated
    Dakar was just the begining.
    X2 what Gussie said: make sure all of your tires are properly inflated. Sounds silly but it really can mess things up.
    '99
    The best thing to do is check to see what the fault indicator light is indicating. I hope this info appies to your model VX with the push button TOD.
    Numbers 4 and 5 are the GND terminals.
    This is a wire that you use to jump the terminals at the data port-
    Here's a video I made showing the TOD check light flashing the code.
    The code is 12 of course, meaning everything is normal.
    5 seconds, 439 kb, wmv file-
    http://www.drivehq.com/file/df.aspx/publish/mgpa/vids/tod.wmv
    5 seconds, 5.9 mb, mpg file-
    http://www.drivehq.com/file/df.aspx/publish/mgpa/vids/tod.mpg
    I hope this was helpful to you.
    Mark Griffin
  1. TOD indicator is flickering,but the check light is'nt on
    By richard davis in forum VX Troubleshooting...
    Last Post: 06/26/2013, 05:24 AM
  2. check light and abs
    By FlyingV77 in forum VX Troubleshooting...
    Last Post: 05/28/2013, 05:23 AM
  3. mode selector switch fix (shift indicator light)
    By kronopoliz in forum VX Troubleshooting...
    Last Post: 11/30/2009, 02:29 AM
  4. TOD Check Light
    By saberwolf in forum VX Troubleshooting...
    Last Post: 12/28/2008, 10:48 PM
  5. CHECK TOD light :(
    By V12BMW in forum VX Talk...
    Last Post: 01/17/2005, 10:03 PM
