looking to do my spark plugs today.. just want to make sure its actually an easy a job as it sounds... 2 screws to remove the ignition coil, a spark plug socket on long extensions to remove the old ones, just check the gap on the spark plugs to 0.040 lube up the threads and boot then torque em down to 13ft lbs?
that sounds too easy...
also just out of curiousity, what type of plug is everyone using.. im torn between the denso iridium 16 and the bosch platinum +4
