bad gas? water in tank? fuel lines clog? fuel filter shot to heck? fouled spark plugs?
Remove the two bolts holding the EGR. Note if loose. Inspect for soot blowby on the gasket. Apply high temp copper coat on both sides of gasket (IF not broken) and retighten.
Cracked vacuum hose at connection.
Roy
Did you cleaned your throttle when replaced IAC? And I'd say to check MAF performance.
1987 AMC Eagle: stock
