Vic (vwbeetle53) has a large group of misc VX bolts listed....
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_1226wt_909
Just wanted to revisit this quick... I just mounted an '04 Axiom fog switch in the fuzzy bezel with no problem. Did take several minutes of Dremel work however, and since it's a tight fit the back of the bezel looks like it went through a meat grinder. On the other hand the switch sits perfectly flush with the blank/tailgate switches, does not move when depressed, and you can't see any of the Dremel carnage from the front.
I found that you need to cut the corner piece but also grind down the plastic "lip" that adjoins the corner. Shaving that piece down just a hair (maybe 1 mm) allows the metal retaining clip to slide all the way through and lock.
So for anybody worried about making these switches fit, don't be!
Link to eBay ad
I am not sure what this is all about, I just went out to the truck, popped out a blank, and the switch went in just fine? I am thinking of removing the useless blinking red light and adding this switch in that location. Not sure what I am gonna hook up though, maybe roof lights?
+1 on the less
And apparently two more lol. He had 6 before I ordered mine a few hours ago. What's funny is that this isn't a new ad; I wonder how we missed it before?
And now the available number is at 10...![]()
You're looking at a different item #, but that is weird. Maybe this guy collects them? How else could someone end up with dozens of these things?![]()
Says that they are new...so maybe he found a closeout deal someplace.
Do you need the factory wire harness to hook them up?
That helps, otherwise you have to fabricate the connections yourself. But then again you would have to splice the wires from the factory harness to your aftermarket lights anyway, so I guess it's the difference between making that splice at the switch pin or further down the wire.
Our very own KAT called out in this eBay ad:
http://cgi.ebay.com/ebaymotors/2000-...Q5fAccessories
No Way!! Too cool! I'd posted about several of his parts on 11/14 but didn't scroll all the way down so I didn't see that!
I hooked up "wintermute" with this seller a while back for some parts he needed. He also sent me a cool pic of his "off road beetle"...it's really funny. Just for s&g I'll see if I can find it and post it.
EDIT- Found the pics! This is Vic's off road VW Beetle! He'd fit in around here with his sense of humor!
Engine out of a '99 with 82k miles, in Wisconsin
http://cgi.ebay.com/ebaymotors/ws/eB...3#ht_858wt_683
