I have 2 products that I have used for the VX and have to say I would 100% recommend.
First.....
Mr. Clean Auto Dry Car Wash System:
This is the only product I have ever used that has delivered on its promises. I have been using it for about 5 years. Usually by this time, I have moved onto the next best thing. The trick to using this is that you do still have to scrub the car. The magic is in the soap and the filtered water. The gun is nice for easy switch betweens. I washed my Ebony VX in the hot sun (water steamed when I sprayed it) and when I was done, I didnt have one single water spot.
Second...
Turtle Wax' ICE
I purchased a bottle of this stuff on Saturday and used it on the VX including the Cladding. It took about 10 minutes to do the whole car. Their claim is that you can use it on EVERYTHING. Plastic, painted, chromed, metal, rubber, etc. It was a breeze to put on. My cladding looks amazing.
) it really speeds the process of putting on the cladding dressing. You still have to do a final wipe down with a cloth to make sure it's perfectly even, but it reduces the elbow grease factor by at least 90%. Just make sure if you're using a cordless drill that you have multiple battery packs ready!
