I tow now with a load-equalizing hitch and it takes any sway right out. Our new 20' 14K lb. trailer is a bit tongue-heavy unloaded and the new hitch makes all the difference. No more towing with my Dad's F-150 though, I'll be using an '86 Mack Ms-250P Midliner that gets over 20MPG and can pull whatever I can load. If it's bigger than that I finally got a 50-ton lowboy for our vintage '70 IHC Transtar!
So what did you find about the 6.2 that's giving you second thoughts? The only significant issue I've found thus far is that you need to keep an eye on the harmonic balancer, but other than that it's got a fantastic track record.
I pulled the trans enough to replace the flex plate and then installed a new gear reduction starter - that was fun - no, seriously, IT WAS FUN!
Plus I had to ruin the straps that hold the tank in place... Grr. Oh well, I have ordered new straps. I have also ordered a new rear end wiring harness and glove box door. After I put the bed back on I think I am going to bob it to the length of a short box!
