This project may be beyond understanding for some, but Operation AWOL is under way... AWOL is an '84 CUCV M1008 Chevy 5/4 ton Army truck honorably discharged from use in the "original" Gulf War. This 6,000 pound hunk of metal came back to The 'States to do ranch work in Wyoming for a couple years until it was retired to a storage unit for a couple more years until I found it and brought it home for $600. It is now in SLC with me... let the work begin...
Additional Specs:
Detroit 6.2 Liter V8 Diesel
TH400 Automatic Transmission
NP208 Transfer Case
Dana 60 Front Axle w/ 4.56 Gears
Corp 14-Bolt Full-Floating Rear Axle w/ 4.56 Gears & Detoit Locker
24/12 Volt Hybrid Electrical System
The '95 Wrangler will be at the frontline and will most likely be the 1st casualty in this operation... Zeus is safe at the HQ for now...
					 Operation AWOL
 Operation AWOL
  Reply With Quote Bart
 However, I do have an '87 Silverado with factory air that's going to donate it's cab and twin-tank bed.  It also has a 700R4 but I'm going to hold off for the manual 5-speed in that department.  Currently 3-color woodland but I want to go sand like yours, much better for the Florida sun.
 The wheel and tire combo is about 100 lbs each and if they get too hot the tire pressure increases and... the bead locks have been known to blow apart!
