Results 1 to 8 of 8
Thread: ATTN. Lifted VXs....
    99 Silver VX
    Finally, got them finished....
    Front axle DROP brackets are what all lifted VXs need to save the CV axles....I made these to drop the front axle 2".
    This will allow the CV axles to run at less of an angle, thus adding to the strength and reliability of them.
    It is a real nightmare to install these though...takes about 8 hrs with hand tools.... So I doubt i'll offer these for sale.
    But for those that are interested, I have posted some pics in the gallery section...
    Also had to "knotch" the crossmember a little, too.
    Links to pics.....
    http://www.vehicross.info/gallery/sh...php?photo=2230
    http://www.vehicross.info/gallery/sh...php?photo=2231
    http://www.vehicross.info/gallery/sh...php?photo=2229
    Allan
    '01 Ironman
    OK I might be wrong but you dropping the axle 2"? So your loosing that clearance in order to keep the CVs straight? I just don't really understand what you did, please expand if you have time.
    Thanx in advance
    Alan
    Re: clearence...
    Originally posted by SPAZZ
    You got it...drop the axle...save the cv's...lose the clearence.... a never ending loop
    keep the ride height.
    99 Silver VX
    Well, with 36" tires and 4+ inches of lift, I don't have ANY clearance problems....period.
    In fact, I just measured it and I have OVER 14" of ground clearance at the lowest part of the front axle!!!!!
    Plenty enough to brag about.
    Allan
    Feb 2003
    '99 Astral Silver 1032
    The height of your diff. will always be a function of your tire size (except for some specialty vehicles…). If you can fit in bigger tires (with the help of some kind of a lift) you have more axle clearance. Period
    VERY nice allan, but what did you do about the steering linkage. Isn't it going to bind now? or did you make a new braket for that as well?
    I was going to make a set of spacers to drop mine but I haven't done it yet. I'm glad to see someone initiated the project.. thumbs up for sureee
    Its the thrill of the chase
    99 Silver VX
    Well, that is the next project, Swordy......
    The steering dosn't bind yet, but the tie rods are at an EXTREEM angle at full droop.
    I hope to relocate the outer tie rod end to the top side of the steering knuckle....but haven't had the time yet....
    I had 3/4 spacers on the front axle, at first, but had problems with the new longer bolts bending due to "axle wrap" or the twisting force on the axle-housing from tourque...and also the axle housing seemed to shift around a bit more than stock....At one point a yr or so ago, the bolts came loose on one side and then all the "twist" was on the other side....so the housing broke (rotated the long side of the axle housing in the punpkin) I had to rotate it back and weld it up.;eekr; .....What a **@#!
    Alan,
    I think it will be fairly easy for you to fabricate a set of brackets to drop down the idler arm and the steering box an inch or so. Thats probably the best and easiest solution. It also will cure a lot of the bump steer. If you have that problem.
    Swordy
  1. ATTN!!!! 5 SPEED SWAP W/TOD DONE!
    By BigMeatVX in forum VX Modifications...
    Last Post: 06/01/2015, 05:48 PM
  2. Attn: Aussie and NZ VX owners
    By AussieVX in forum Japanese Domestic Model (JDM) VXs
    Last Post: 06/25/2012, 06:18 AM
  3. ATTN photoshop people, need some help
    Last Post: 04/14/2010, 07:36 PM
  4. ATTN: Engineers - need a contact for CO
    By driver3 in forum VX Talk...
    Last Post: 09/11/2006, 05:24 PM
  5. Attn: thedutchguy
    By mbeach in forum VX Troubleshooting...
    Last Post: 12/20/2005, 10:55 AM
