Results 1 to 3 of 3
Thread: ABS light on intermittently
    My ABS light is coming on intermittently. Is this a problem or can I drive the beast with it this way and not worry about brakes, etc?
    DeepSilentComplete :coolr:
    He postulated that cognitive simulacra might one day approximate component models of the psyche.
    mine is actually doing the same thing since kane creek in moab this year....
    it seems to act up more when its wet outside..
    yep.. sounds like an abs module on its way out.. mine would do it when warm, then once it cooled down the light would go back out.. eventually happened more and more until it was steady on.. the brakes worked fine, just had no abs which was fine with me, just take a bit of time to get a feel for emergency braking in a safe place without abs
    its also pretty easy to change your abs module yourself if you can find the unit, i know its identical to either the trooper or rodeo with 4 wheel disc brakes but i cant remember which one... either way used is the way to go as the dealer charges 2500 for the part
    check here for instructions on replacing the unit at home
    http://www.vehicross.info/modules.ph...warticle&id=50
  1. Help with wiring light acces. to dome light
    By tysamigo in forum VX Troubleshooting...
    Last Post: 11/24/2013, 08:49 PM
  2. Blower Functioning Intermittently
    By Breezy in forum VX Troubleshooting...
    Last Post: 11/03/2011, 11:51 AM
  3. Rear cargo light + underhood light
    Last Post: 05/29/2010, 08:00 AM
  4. spoiler tail light / hazard light question !
    By Spike in forum VX Talk...
    Last Post: 05/21/2007, 08:27 PM
  5. Dead short in Rear Light/Instrument light
    By Damien Jones in forum VX Troubleshooting...
    Last Post: 07/16/2006, 07:49 PM
