Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Thread: Alarm antenna
  1. #16
    2000, Ebony, VX, 0370
    Thanked: 12
    Tom, I don't know why it didn't work for you. I am being totally serious when I tell you that it DOES work. There is a limit to the distance that it will boost the signal, but it does help.
    To clarify; I have the stock VX alarm system and key fob. If I place the tip of the fob (that I usually point at the car) against my temple and then press the arm/disarm button it can, sometimes, triple the distance that I can arm/disarm the alarm from. Some have had some luck with placing the fob under their jaw (in the squishy part).
    Could also be that your head just isn't a good conductor.
  2. #17
    Are you saying I'm dense???
    I know I didn't really test it. I was walking out of KFC & hit the button on the FOB - Nothing. Put FOB under chin & hit button - worked. Hit button again (not under chin) - worked.
    I'll try again under controlled conditions (no witnesses)
  3. #18
    Thanked: 12
    I have nothing to say to that....
  1. VW antenna
    Last Post: 12/10/2014, 01:44 PM
  2. New CB Antenna
    Last Post: 02/13/2010, 12:07 PM
  3. CB Antenna
    By tomdietrying in forum VX Talk...
    Last Post: 02/09/2009, 09:59 AM
  4. Thanks, carlymac, for the lock/alarm antenna mod
    By workmeistr in forum VX Modifications...
    Last Post: 11/29/2008, 02:12 PM
  5. i need a new antenna
    By autox-racer in forum VX Talk...
    Last Post: 10/01/2002, 04:25 PM
