Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Thread: Colorado Emissions
    Oct 2012
    2001, Proton, 0586
    Most states exempt AWD vehicles from the roller test, because it isn't as safe to perform. Was CO actually testing VX on 2WD rollers?
    Nov 2012
    No, Colorado has a lot of AWD vehicles so they have a couple of lanes that are specifically made for AWD. It depends on the vehicle what method they use though. I've got a Subaru WRX that goes on the rollers but my VX they took to the side and ran the no load tests.
    There's no 'I' in denial.
    May 2007
    1999 Black Rodeo
    Just FYI for Colorado peeps with large tires.
    Q.
    Tire Sizes and Dynamometers?
    A.
    Front wheel and all wheel drive vehicles with low profile tire sizes 17 inches or larger in diameter, or vehicles with tire sizes larger than 34 inches cannot be safely tested on the dynamometer.
    Only vehicles with manufacturer-equipped undersized or oversized tires that do not fit safely on the dynamometer will be authorized by the state to undergo an idle test instead of a dynamometer test. Vehicles with tires larger or smaller than original equipment that do not fit safely on the dynamometer must be returned to stock condition for testing. Vehicles with non-original undersized or oversized tires will not receive authorization from the state for an idle test.
    I had to take the Vulva to the AWD lane but I'm pretty sure the wheel base in it is longer then a VX.
    --Dave
    Quote Originally Posted by Gizmo42 View Post
    That's why I register the VX in Colorado Springs where they happily accept your money without emissions.
  1. California Emissions ARB Catalytic Converter on 1999 Vehicross
    By KILNA in forum VX Troubleshooting...
    Last Post: 10/26/2020, 07:57 PM
  2. passing emissions with an Evap Check Engine Light
    By bearandbee in forum VX Troubleshooting...
    Last Post: 11/18/2011, 01:38 PM
  3. Colorado 'Zu IX
    By Locomigo in forum Meets...
    Last Post: 07/03/2007, 12:38 PM
  4. Colorado Zu
    By Triathlete in forum Meets...
    Last Post: 08/11/2006, 09:59 AM
