Thats what I described above only with tubing instead of a box and instead of mounting to the door mount to the floor with a hinge so it swings down and out!with all this talk, i have actually came up with a great idea... may work for some, maybe not for others, i havent actually measured so i dont know, but its worth a try...
why not build a wooden or metal box where the factory spare goes, and mount your full size spare on the inside of that??
would eliminate our small amount of cargo space, but would hold the tire, take the weight off the sheet metal, and still be able to carry a full size spare...![]()
Hmmm, my main question is: Is the full-size spare planned to be VX carried full-time OR only on off-road outings???
If the full-size spare is only planned for off-road outings, then the "donut" should be retained for urban travel.
Another option for those with no back seat might be a cradle with a ratchet strap over the top of the tire like the ralley trucks use...
Alright boys and girls, as promised I completed the project. I now know why there is no deformation on Toms door. It isn't just sheet metal. The outer painted piece is standard body sheet metal, but it is layered on top of some pretty thick stuff. I did not go the same route as Tom's PO did. I used longer bolts and went all the way through the inner spare support portion. I used 3/8" bolts, 4.5 inches long with nylock nuts. I mounted it more like studs, with the head of the bolt inside the door. This enabled me to keep my gas can in the door. Now the weight should not be on the outer steel, but most should be distributed inside the spare area, which is also some heavy duty steel. Overall, including removing the isuzu badge, took about 1.25 hours or so. Not long at all. It came out pretty good, I still need to find a way to mount the license plate, but the way I have will do for now. I was running around with no rear cladding and on the way to Ace Hardware, I cop turned around in the road to come get me, but I think he got a call, cause he ended up doin a 360 with his lights on, I was the only other car out, but on the way home, I saw what I assume to be the same cop at a house with his lights on...seriously doubt I would have gotten a ticket, if I explained what I was doin, I had the plate in the passenger seat.
If anyone has anymore questions about this project, it is pretty easy. The door didn't seem to hang any different, as I said, a 20% weight change is not significant. Once again, the bracket came off of a Pathfinder, it has a padlock stud built into it. The angle of departure and approach shouldn't be affected too much either, it sits pretty high off the ground.
Materials needed:
Drill, 3/8" metal bit
4 3/8x4.5" bolts, 8 flat washers, 4 lock washers and 4 nylock nuts
9/16 socket, and a 9/16 wrench
sharpie marker
tape measure
1 spare mount off of a Nissan Pathfinder(make sure you get all three lugnuts too, I only got two, I am a dummy...)
Some tool drawer rubber or somethin for behind the bracket
Primer(for the holes after you drill them)
Putty knife for taking the ISUZU badge off and some goo gone for residue.
An extra hand may be needed when tightening the bolts, I couldn't reach all the way inside and outside at the same time.
I had to take the cladding off, I wish I had mounted it about 2 inches higher. The bottom bolts ended up on curved portion of the door, which was a PITA to drill, hence the cladding removal, I did tear up some plastic trying to drill those holes out, but nothing you can see once the bracket is mounted. Overall I put this project at a 6 out of 10, but only cause you gotta measure precisely or else risk it being crooked. I think mine may be off a tiny bit, but nothing significant. I did notice that my bracket is a little bent, that is my bad, didn't check at the junkyard, but no biggie. The only deformation was a bit of the cladding, as you tighten the bolts down, it compresses the cladding a bit, but nothing extreme.
Here are the pics:
The biggest problem I noted, my stickers are covered up!!!!!!!! Now I have to move my extra Jeep Recovery Sticker, glad I bought two.![]()
The door opens smoothly, no rubbing, nothing abnormal at all from what I can tell. I bounced it around, hung on the spare, no bending of the metal. I think this is a solid mount. For those looking for an option, I think this is a good one...
I would think you could get away with a different size in the front...if you have manual hubs!!!!!!!!!!!!!!! That is why that is my next mod, plus I wanna do donuts and I like the idea of being able to disengage the front in case of CV problems. That way I can still drive it.
Not too bad. I just am not sold on it yet. I would love to see one in person to decide for myself if I want to do this. I think it looks unfinished. As I dont need or even have a rear seat anymore I am still thinking of going with the inside vertical mount like I have been planning.
Edit: After thinking about it. I wonder about something that would be a little lower. Like where the lower cladding is. Something that I could remove for around town use and put the tire inside and would not ruin the look of the door by having an ugly bracket sitting there. But on trips when the back is loaded and I want the space that the spare is taking by standing there I could pull it and mount it back there. Hmmm. I'll need to think about this more....
