Marlin, as far as the hubs...if he will give you a good deal take them. Even if they don't fit you can clean them up and double your money saling them on PlanetIsuzoo.com. Give Matt at Indy4x a call and he will know if they will work. Are they Warn or Asins? They should be 17 spline I believe.
I do know ours are 17 spline. Kodiak, what brand are yours, they look indentical to the ones you had on. The red face style.
I will try tomorrow.
As far as the foam under the bracket, I was actually planning on using the non-skid type tool drawer liner, it should prevent the bracket from rubbing against the door, thus preventing rust. It also will give a bit of room for water to evaporate.
I believe that it the rear door will look fine with the tire. It is already shaped like the tire, even the rear window is curved to match. Mine will also cover my dent
