Results 1 to 15 of 139
Thread: Rear Door Spare Tire Mount
    Marlin,
    I forgot to mention that the PO put a layer of padding (some kind of closed cell foam) under the bracket. He only did it on the outside bracket though.
    You can sorta see it in my pix (but only if you're looking for it).
    Marlin, as far as the hubs...if he will give you a good deal take them. Even if they don't fit you can clean them up and double your money saling them on PlanetIsuzoo.com. Give Matt at Indy4x a call and he will know if they will work. Are they Warn or Asins? They should be 17 spline I believe.
    01, LineX tan/black, 1055
    I do know ours are 17 spline. Kodiak, what brand are yours, they look indentical to the ones you had on. The red face style.
    I will try tomorrow.
    As far as the foam under the bracket, I was actually planning on using the non-skid type tool drawer liner, it should prevent the bracket from rubbing against the door, thus preventing rust. It also will give a bit of room for water to evaporate.
    I believe that it the rear door will look fine with the tire. It is already shaped like the tire, even the rear window is curved to match. Mine will also cover my dent
    Apr 2007
    2001, Proton #1238
    They’re stock Aisin manual hubs. They came off of a first gen Rodeo. They sell for about $25 each here. I haven’t been to pick and pull this month. I’m waiting for one of there 50% off days.
  1. Spare tire mod
    Last Post: 10/04/2010, 10:23 PM
  2. Use of spare place of spare tire...
    By uncle_asa in forum General Tips...
    Last Post: 08/10/2009, 11:31 AM
  3. Easiest Spare Tire Mount Possible
    By VX1032 in forum VX Modifications...
    Last Post: 06/15/2009, 12:00 PM
  4. Spare tire vs Tire Sealer?
    By Petos in forum VX Talk...
    Last Post: 04/25/2008, 08:02 AM
  5. Aerodynamics / Tow Hitch Spare Tire Mount
    Last Post: 01/06/2005, 09:51 AM
