Results 1 to 15 of 139
Thread: Rear Door Spare Tire Mount
    Hope y'all like the smell of rubber. Having the spare inside will certainly add to the ambience.
    Hope y'all like the smell of rubber. Having the spare inside will certainly add to the amviance (sp?).
    Nothing was worse than the original rubber mat I bought to line my cargo space. The smell was like roofer's tar...or 1000 cartons of cigarettes were smoked inside my VX. It was just horrible and had to go...
    "has anyone mentioned that mounting the spare on the outside of the rear door completely defaces the nice looking booty of our beloved VXes?"
    No but I was waiting.
    IMHO, the spare actually continues the body line 'in a quite aestetically pleasing manner.'
    (sorry for the paraphrase - can't remember where it came from)
    "Nothing was worse than the original rubber mat I bought to line my cargo space."
    I know what you mean. I had to 'cook' my rubber floor mats in the sun for a week before I could put them in the car.
    i got one up on you.. check my other thread for details..
    with all this talk, i have actually came up with a great idea... may work for some, maybe not for others, i havent actually measured so i dont know, but its worth a try...
    why not build a wooden or metal box where the factory spare goes, and mount your full size spare on the inside of that??
    would eliminate our small amount of cargo space, but would hold the tire, take the weight off the sheet metal, and still be able to carry a full size spare...
    Thats what I described above only with tubing instead of a box and instead of mounting to the door mount to the floor with a hinge so it swings down and out!
    great minds think alike
    Aug 2008
    Hmmm, my main question is: Is the full-size spare planned to be VX carried full-time OR only on off-road outings???
    If the full-size spare is only planned for off-road outings, then the "donut" should be retained for urban travel.
    donut will not work if you change your tires from stock AT ALL....
    i keep my full size spare with me all the time...
    Another option for those with no back seat might be a cradle with a ratchet strap over the top of the tire like the ralley trucks use...
    2001, Ebony Black, 1153
    Yeah never ever put any other sized tire on the VX on any one or two tires, your TOD will fry like a poptart's wrapper in the microwave
    01, LineX tan/black, 1055
    Alright boys and girls, as promised I completed the project. I now know why there is no deformation on Toms door. It isn't just sheet metal. The outer painted piece is standard body sheet metal, but it is layered on top of some pretty thick stuff. I did not go the same route as Tom's PO did. I used longer bolts and went all the way through the inner spare support portion. I used 3/8" bolts, 4.5 inches long with nylock nuts. I mounted it more like studs, with the head of the bolt inside the door. This enabled me to keep my gas can in the door. Now the weight should not be on the outer steel, but most should be distributed inside the spare area, which is also some heavy duty steel. Overall, including removing the isuzu badge, took about 1.25 hours or so. Not long at all. It came out pretty good, I still need to find a way to mount the license plate, but the way I have will do for now. I was running around with no rear cladding and on the way to Ace Hardware, I cop turned around in the road to come get me, but I think he got a call, cause he ended up doin a 360 with his lights on, I was the only other car out, but on the way home, I saw what I assume to be the same cop at a house with his lights on...seriously doubt I would have gotten a ticket, if I explained what I was doin, I had the plate in the passenger seat.
    If anyone has anymore questions about this project, it is pretty easy. The door didn't seem to hang any different, as I said, a 20% weight change is not significant. Once again, the bracket came off of a Pathfinder, it has a padlock stud built into it. The angle of departure and approach shouldn't be affected too much either, it sits pretty high off the ground.
    Materials needed:
    Drill, 3/8" metal bit
    4 3/8x4.5" bolts, 8 flat washers, 4 lock washers and 4 nylock nuts
    9/16 socket, and a 9/16 wrench
    sharpie marker
    tape measure
    1 spare mount off of a Nissan Pathfinder(make sure you get all three lugnuts too, I only got two, I am a dummy...)
    Some tool drawer rubber or somethin for behind the bracket
    Primer(for the holes after you drill them)
    Putty knife for taking the ISUZU badge off and some goo gone for residue.
    An extra hand may be needed when tightening the bolts, I couldn't reach all the way inside and outside at the same time.
    I had to take the cladding off, I wish I had mounted it about 2 inches higher. The bottom bolts ended up on curved portion of the door, which was a PITA to drill, hence the cladding removal, I did tear up some plastic trying to drill those holes out, but nothing you can see once the bracket is mounted. Overall I put this project at a 6 out of 10, but only cause you gotta measure precisely or else risk it being crooked. I think mine may be off a tiny bit, but nothing significant. I did notice that my bracket is a little bent, that is my bad, didn't check at the junkyard, but no biggie. The only deformation was a bit of the cladding, as you tighten the bolts down, it compresses the cladding a bit, but nothing extreme.
    Here are the pics:
    I would think you could get away with a different size in the front...if you have manual hubs!!!!!!!!!!!!!!! That is why that is my next mod, plus I wanna do donuts and I like the idea of being able to disengage the front in case of CV problems. That way I can still drive it.
  1. Spare tire mod
    Last Post: 10/04/2010, 10:23 PM
  2. Use of spare place of spare tire...
    By uncle_asa in forum General Tips...
    Last Post: 08/10/2009, 11:31 AM
  3. Easiest Spare Tire Mount Possible
    By VX1032 in forum VX Modifications...
    Last Post: 06/15/2009, 12:00 PM
  4. Spare tire vs Tire Sealer?
    By Petos in forum VX Talk...
    Last Post: 04/25/2008, 08:02 AM
  5. Aerodynamics / Tow Hitch Spare Tire Mount
    Last Post: 01/06/2005, 09:51 AM
