A lot of you have made it ABUNDANTLY clear how you feel about mounting a full size spare on the rear door. You don't need to repeat yourself. I heard you the first time
Others have asked how the PO mounted it on mine so here are a few pix:
http://pbase.com/tom4bren/090530_window_fixin_party
I probably should have made a seperate folder but all the pix were taken at the same time.
The U-channel on the outside of the back door looks like a factory piece he scrounged from somewhere. I don't know what the hub piece is that he welded to it but the studs are just press in.
Inside the door are two rather hefty plates to spread out the load so that the sheet metal isn't deformed.
I'll try to get the pix loaded in my gallery later (for some reason, they wouldn't take).
