Results 1 to 15 of 24
Thread: How to replace lower ball joint?????
    2001, Ebony Black, 1153
    Quote Originally Posted by E-ZooZoo One View Post
    I vaguely recall running into a clearance issue when changing my lower Ball Joints…
    IIRC, with the upper Ball Joint already disconnected, we had to disassemble the outer hub assembly, down to the retainer C-clip – slide the CV shaft out the back (with just BARELY enough room to do so) – and then, with the CV shaft held up out of the way, there was enough clearance to lift the spindle off of the lower Ball Joint.
    That is exactly what I was thinking, but I really wanted to avoid that if at all possible. Thanks.
    Sep 2003
    `99 Astral #1889 (sold) | `95 Trooper TeraLows-5.38s-35s | `98 Acura SLX
    On the bright side, you can re-pack your bearings while you're at it
    Cheers!
    Smiley
    "This trail is so bumpy, it's knocking my bra straps off!" - Miss Kathy
    Cheers!
    Smiley
    Do I have to disassemble EVERYTHING to get the cv cup loose that you would have to disassemble to re-pack? If so I guess I might as well. Oh well more money and more time.
    Sep 2003
    IIRC, no, you don't have to tear it down quite that far... but the way I see it, if you're already that close, why not go ahead and re-pack the bearings while you're at it? --- Other than being a little messy, it's not that hard -- hell , *I* can do it!
    Cheers!
    Smiley
    Ryan did you get this finished? I just noticed that I've got a torn boot over my lower ball joint. any advice would be much appreciated!
  1. Lower Ball Joints Removal
    Last Post: 10/06/2016, 04:58 AM
  2. Replies: 6
    Last Post: 07/18/2014, 08:39 PM
  3. A note on lower ball joint / control arm bolts
    Last Post: 01/06/2014, 05:06 PM
  4. Ball Joints - Upper and Lower
    Last Post: 11/27/2012, 03:54 PM
  5. Ball Joint?
    By V12BMW in forum VX Talk...
    Last Post: 11/13/2004, 08:42 AM
