Results 1 to 15 of 24
Thread: How to replace lower ball joint?????
    2001, Ebony Black, 1153
    Yeah that is what I am looking at now, LOL, you do have to remove everything to the left of the outer CV joint in order to replace the lower ball joint (according to the manual), haha, wow, this is going to be really fun
    I guess I should just follow the repacking the front bearings protocol and then remove the outer CV joint and then replace the lower ball joint, blah!!!!!
    Feb 2005
    01 Kaiser Silver
    Hey Ryan I replaced mine but had assitance.. Forgive me for my teminolgy is lacking but my Old roomeys husband who is a mechanic did it and it only took maybe 15-20 minutes maybe less if I wasnt helping lol.. I will have to crawl under there today after work and check see if I can remember.. I should have taken pictures but was replacing a bunch of stuff with HD stuff and well got oer my head on the weekend so I got assitance to finish in time for work monday lol..
    Quote Originally Posted by Dumke View Post
    Any other ball joint, including the upper ones, steering linkage and all the others are very easy to remove (once you get them broken loose), but the lower one is wedged in there by the outer CV attachment and there really seems to be no way around having to take apart and remove the outer CV by releasing it from disassembling the entire HUB. I would love to know how he did this as the closest I can get is 1/2 the way off until it starts wedging itself at an angle under the CV cup. But if it is true then I have hope, maybe you can talk to your mechanic friend and then enlighten me, thanks.
    My guess is that Rob is referring to the upper ball joint flip...
    I could see that taking twenty min/side if it was already off the ground with the tires/wheels off...
    But I don't see any way you could get the lowers done in that amount of time...
    Feb 2005
    01 Kaiser Silver
    Dub I actually changed both of my to HD or whatever.. was part of kit i bought. I flipped upper and changed lower.
    Ryan he didnt call me back yet but when I looked under there after work that how I think he did it... Tires off of course. pull rotor and blah blah other stuff.. when I get details which hopefully by tomorrow he will let me know or call back. i will be calling him tomorrow.
    Sep 2003
    `99 Astral #1889 (sold) | `95 Trooper TeraLows-5.38s-35s | `98 Acura SLX
    I vaguely recall running into a clearance issue when changing my lower Ball Joints…
    IIRC, with the upper Ball Joint already disconnected, we had to disassemble the outer hub assembly, down to the retainer C-clip – slide the CV shaft out the back (with just BARELY enough room to do so) – and then, with the CV shaft held up out of the way, there was enough clearance to lift the spindle off of the lower Ball Joint.
    HTH
    Cheers!
    Smiley
    "This trail is so bumpy, it's knocking my bra straps off!" - Miss Kathy
    Quote Originally Posted by E-ZooZoo One View Post
    That is exactly what I was thinking, but I really wanted to avoid that if at all possible. Thanks.
  1. Lower Ball Joints Removal
    Last Post: 10/06/2016, 04:58 AM
  2. Replies: 6
    Last Post: 07/18/2014, 08:39 PM
  3. A note on lower ball joint / control arm bolts
    Last Post: 01/06/2014, 05:06 PM
  4. Ball Joints - Upper and Lower
    Last Post: 11/27/2012, 03:54 PM
  5. Ball Joint?
    By V12BMW in forum VX Talk...
    Last Post: 11/13/2004, 08:42 AM
