Results 1 to 15 of 27
Thread: Front Diff Issue (Leak)
    J, so you replaced the inner seal and it STILL leaks? I have seals for both sides and I am planning on doing them this summer. Did you use a seal driver? Did you use OEM seals?
    2000, Ebony, VX, 0370
    Thanked: 12
    I actually have small leak in my drivers side axle seal. It happened after I had my CV issues on that side and the shop that did all of the work said that it was a little difficult to get the seal seated correctly so that may be the issue that you're having.
    Bart,
    If you're talking about the seals on the axles, then no seal driver is needed. The diff drop installation instructions available cover it pretty good. I think I needed to use a piece of PVC pipe as a slide hammer for the bearings but they went on pretty easy too.
  1. Front Diff drop help for 8" lift
    By superstang460 in forum VX Modifications...
    Last Post: 04/20/2011, 04:33 AM
  2. Powertrax Front Diff Option?
    By ZEUS in forum VX Modifications...
    Last Post: 03/07/2011, 02:52 PM
  3. Sump / Front Diff Guards
    Last Post: 03/20/2009, 11:02 AM
  4. Replies: 2
    Last Post: 03/09/2007, 12:42 PM
  5. Need Front and Rear Diff low down.
