Results 1 to 15 of 18
Thread: EGR, Check engine Light ,LOW FLOW
    Sep 2009
    '99,White,Ironman,1564
    I need some help here. I tried almost everything; clean the valve, spray carb cleaner, brake cleaner in the intake. But the light still on with same code Egr Low Flow. Do I better buy another Valve? Mine is from Global Automotive.
    [Ip://http://www.vehicross.info/gallery/data/500/medium/Image250.jpg
    Probably a dumb question but did you reset the computer when you were done (disconnect the battery for 20 minutes)?
    Aug 2005
    1999, silver, 0887
    Good advice.
    Gas cap not on tight???
    Rumor has it that can throw some strange codes.
    Dec 2004
    '99 VX Astral Silver #0949
    I replaced my EGR w OEM version. Two weeks later same low flow.
    It goes away once in awhile. But a big fat waste of money IMHO.
    The computer should be programed to ignore this code as a Check Engine alarm IMHO
    Sometimes I Wonder......
    Why Is That Frizbee Getting Bigger?
    Then It Hits Me
    Sep 2009
    EGR code, my nightmare
    I tried disconnecting the battery, not exactly for more than five minutes, but I'm gonna try the 20 mins suggestion. I heard that with the engine running, and with valve disconnected, I can see if it's working or not (the valve open and close while you accelerate in the throttle. Is that true? Thank you all for the advices.
    Jan 2007
    *BHC* 1999 Ironman. :D 0454
    My 2 cents on this, I bought OAM EGR valve new, nothing happened. Cleaned it out completely, nothing happened. Did the battery thing, nothing happened. Really there is prob.. nothing you can do but live with the light, and if it flashes, then you really have a problem My only suggestion is to change the solenoid, the one thing i keep forgetting to do, can't remember the name of the solenoid, but may be some 1 here can let you know, or easier, just search it, its out there, i know. But i can be wrong, and i hope you fix it, good luck Mae.
    Turning My VX Into Rally VX
    Sep 2009
    Smile
    After cleaning mine with carb cleaner several times, it finally gave up the ghost...replaced it with one from auto zone, it threw codes for about two weeks, then quit.
    Been good for 3 months since.
    Have you tried cleaning the carbon out of your egr tube?
    Hi, I tried, or I think I did; I disconnect the valve and spray two cans of brake cleaner on both holes, mostly in the little one that works like an intake. Do you have any "step by step" procedure? Thank for you time for help me.
    '99
    I can't believe you sprayed that much brake cleaner into your intake! Why? That stuff is way too powerful and can really damage your cats and O2 sensors and who knows what else. Just use carb cleaner.
    Until you know what's wrong you're just guessing by replacing the EGR valve. It may be working just fine. It could be other stuff including wires.
    You never said what code you were getting. I suppose it's P0401. Go to Walmart and get a code reader so you can read and erase codes yourself.
    Mark
    Sep 2009
    Thumbs up egr
    Thanks deermagnet for this valuable information. I don't remember who told to use break cleaner, but did the same. Tried on the EGR valve and did the same as a throttle cleaner, but thank for telling me that I'll be careful. I forgot to say that all this problem begins right after rebuilding the transmission. First the light for Check trans turns on. My mechanic used his computer and erased the code but then the code for the EGR comes up, the same you mention. Got fixed the coolant sensor cable (accelerates way up above 1500rpm's)and the trans begins to work properly(it did not use the overdrive on highway above 55mph). I'm going to follow your tip and buy a code reader, and maybe learn to live with this light on if I can't fix it.
    Thanks a lot for your interest and help
    Jan 2008
    1999 Astral Silver 0481
    Axel as i told you on facebook check the wiring related to the EGR to make sure it's properly working,don't disregard the fact that the wiring can be faulty.
    By the way which is the code ?
    Dakar was just the begining.
    1999 silver 1346
    my engine light came on again and its due for an inspection,perfect timming. I used to just unplug the battery for 20 minutes and this would fix the problem for about 200 - 300 miles but now it only last 16 miles befor comming back on.
    I have 2 question. I was told that if you reset the light and try to inspect the car it will fail if not driven a certain amount of time. does anyone know how many miles this is?
    and there used to be a great write up on cleaning out the egr valve with pictures and a step by step does anyone know where this is?
    thanks
    1999 silver 1346
    after a lot of searching i finally found what i was looking for . a detailed step by step to clean the egr
    http://www.icess.ucsb.edu/~greg/rodeo/egr.htm
    Oct 2008
    UK Sunburst Ltd 000/175
    Thanks for the posting. I'll be doing this little job in the next couple of weeks and it's always good to have some pictures and detailed instructions. Dam that EGR valve.
    Jan 2008
    Quote Originally Posted by zadam123 View Post
    thanks
    I personally never heard about that.
    Since our VX is a all full time 4WD our trucks can not be tested over the dyno,but the inspection is computed-controlled so i guess that situation is possible
  1. Check engine light
    By Rox in forum VX Troubleshooting...
    Last Post: 03/23/2013, 05:17 PM
  2. Check engine light
    By Frank Willen in forum VX Troubleshooting...
    Last Post: 03/21/2011, 04:33 PM
  3. Check Engine Light
    Last Post: 11/05/2007, 08:11 AM
  4. Check Engine Light
  5. Check Engine light
    Last Post: 03/22/2004, 03:35 AM
