Results 1 to 6 of 6
Thread: o2 sensor no activity diagnosis
    Dec 2006
    99, Silver, 1972
    sold
    since you don't give all the specifics, i.e., individual input and output voltages, I'd suggest physically swapping the sensors. also check wiring for abraisions, burns, shorts and continuity.
    well...i dont really know much about O2 sensors but...isnt the point to make sure your burning proper and clean out of your exhaust??
    if so, then with switching the wires and it still reads same side? that suggests that there is actually a bad fuel or exhaust issue...
    i dunno...maybe im completely off
    iirc some have had a dirty MAF give weird O2 sensor readings, you could try cleaning that?
    97 Jap Import, Black BEAST
    If you say you have tried plugging the O2 sensors into each other and therfore eliminating the fault to be with the sensors it must be the wire for Bank 1 sensor thats at fault? do you have a wiring diagram of the ECU. Maybe you can un-plug the wire from the ecu and run a new temporary wire to the ecu from bank 1 O2 sensor and see what the results are?
    Was the voltage reading coming from the sensors? was it pulsating or a constant? Everytime i have checked O2 sensors the signal is pulsating when they are working correctly
    Dec 2006
    99, Silver, 1972
    sold
  1. Help / diagnosis needed
    By Paul_A in forum VX Troubleshooting...
    Last Post: 04/23/2013, 08:25 PM
  2. Learn from my mistake: clunking diagnosis
    By Joe_Black in forum VX Troubleshooting...
    Last Post: 08/03/2011, 07:20 AM
  3. ISUZU Diagnosis computer system on EBay!
    By kodiak in forum VX Talk...
    Last Post: 05/16/2008, 03:24 PM
  4. O2 Sensor/Coolant Temperature Sensor
    Last Post: 04/21/2007, 01:50 AM
  5. New noise - got a diagnosis?
    By Heraclid in forum VX Troubleshooting...
    Last Post: 12/09/2005, 07:55 PM
