Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Thread: this isnt looking good....
  1. #16
    May 2003
    Wink
    ya, i had it welded on today...the rear axle is welded anyhow so the welder said it wouldnt loose strength with the extra weld....
    now im freaking out... i have NO access to a corded drill, only my cordless that is definately not strong enough to drill through our frame...
    gonna have to get creative
    I installed mine & it took multiple drills for me to get the job done. I used a 90 degree "big" Milwaukee corded drill (borrowed from Dad !) for the main mounting holes in the frame & where that wouldn't fit I used a smaller DeWalt 90 degree rechargeable drill (borrowed from Home Depot ) for a couple on the frame and for the small holes along the sheet metal under your door I used a pneumatic 90 degree (borrowed from my mechanic/beer buddy ) with different length bits (**ground shanks down on like 2 bits IIRC).
    Also..on the frame...I marked each hole, then center-punched, drilled each hole small first (pilot) and then drilled a mid-sized hole followed by the desired size. Don't ask me what the desired size was as I can't 'member. (Alzheimer's )
    Could probably do it with just the latter two drills I mentioned....but, have to admit the big 'ole' Milwaukee made short work of the first frame holes I used it on while the DeWalt had to work some (not as much torque). The pneumatic 90 degree drill "barely" fit to do the small holes & had to be positioned in various positions with different length bits to pull off the job. This was my experience anyways!
    **IIRC I had to grind one bit's shank down alot as the pneumatic drill & bit combo barely fit in place to start drilling each hole. Had to insert "shorter-modified" bit into hole of slider...position pneumatic drill with chuck open..close chuck & drill hole until chuck bottoms out on slider...remove drill & bit...insert "longer-modifed" bit into same hole of slider...close chuck & drill hole through...repeat for next hole!
    Hope this helps!
    P.S.---The only other way I could see making it easier to drill the sheet-metal small holes under the door would be to some how mark the holes & remove sliders..drill holes..than re-install sliders & put in your small bolts. I didn't do it this way because I had already mounted my big bolts into the frame to hold the slider in position along with a floor jack & block of wood to coax it in position while I did the small holes with pneumatic drill.
  2. #17
    ya, i found a corded drill i will be using tomorrow to make it work...got all the bits...now all i gotta do is spend the time to do it..
    i have a heavy duty 90 degree attachment for drills so i should be good there..i have both a smaller and a larger 90 bit (use it at work all the time)
    I still think the handgun idea would save you alot of time...
  4. #19
    dont have a handgun...but i have a shotgun
  5. #20
    Mar 2005
    01 Ebony - #0379
    Question
    If doing bolt on, do you need to sleeve the bolts so as not to "crush" the frame as you tighten them up?
    I put a big washer on the back of mine when I bolted, but never thought of the pinching of the box frame - if it's even an issue...
  6. #21
    Quote Originally Posted by Kenny View Post
    Good point ...
    Even beyone tightening, how aboot "spirited" slider use...
  7. #22
    i think the weight is spread out enough that its not going to be an issue...they have 10 bolts per side...
  8. #23
    good news....
    THEY'RE ON!!!!!!!
    7 hours today by myself..
  9. #24
    Apr 2007
    2001, Proton #1238
    Very cool!! Can't wait to see them.
  10. #25
    Jul 2007
    1999,Astral Silver,VX,1349
    take some pics of them finished..we would like to see them
    [SIGPIC][/SIGPIC]...
  11. #26
    May 2003
    Wink
    good news....
    THEY'RE ON!!!!!!!
    I think you beat my time by 'aboot' an hour! I 'member it being like 4hrs per side by myself. Great to hear you were triumphant!!!!!!!
  1. not a good day
    By Daly in forum VX Modifications...
    Last Post: 08/09/2010, 12:11 PM
  2. Think the VXs horn isnt adaquate?
    By KaNGiX in forum VX Talk...
    Last Post: 04/28/2008, 05:06 PM
  3. Good-bye TOD
    Last Post: 10/22/2007, 11:44 AM
  4. first good mud day in the VX
    By iamjacksadrenalgland in forum VX Talk...
    Last Post: 09/17/2006, 05:25 PM
  5. Thank you all and good bye !
    By Andrey in forum VX Talk...
    Last Post: 08/22/2006, 11:24 AM
