Paul,Originally posted by paultvx
Yeah.. I expected it'd run 92 octane. (Aftterall, there's no such thing as free horsepower.) Wishful thinking got the better of me. You know how it goes...
This is contrary to a bunch of posts on the other board lately; the consensus there is that high octane in a VX is a waste. I'd think (others may correct me) that the S/C would not impact which gas you'd use, since it's still the same engine.
I'm *so* exposing myself to an onslaught here...
FWIW, I like the idea of a decent heat shield. Bear in mind that the air intake is in front on the stock engine, but the S/C flips it to the rear of the engine. Don Moody already has something for the stock setup; you might want to just do something for the S/C enhanced crowd. Just a thought.Based on the pictures I saw of the SC... looks like it was designed to work with the stock airbox... it doesn't look like the MAF sensor locatiion is changed.
If I make a intake kit for a NA car, it should work with the SC... right? I'll be getting a filter through work in a week or so, once I get it I will start the prototyping work. A thread will be started for that to keep you guys informed. Keep an eye open.
Oh BTW, the kit will be quite a bit cheaper than Calmini's kit.. and that kit has no heatshield. [/B]
I'm definitly going to make a heat shield... just a matter of when I get my hands on a filter. Hopefully soon.
