I didn't say it was hard to set. The only difficulty in its installation or setup is access. I only wanted to see where others have theirs set to... amazingly, that wasn't understood. Tranny was fine before the Interceptor. With it, normal acceleration is fine. I did state that clearly.Originally posted by Tone
Interceptor should not be this difficult to set! Install is by far the hardest part. 2 sets of instructions are included with it and there are arrows on the device itself for increasing or decreasing line pressure and delay, although they are opposite one another since they are the same pot on different ends of the circuit board.
BTW, there was no red wire with silver stripe as described in your instructions in my 2001.
I see no reason to keep the VX running while adjustments are made. It should work either way and shouldn't make any difference.
