That does suck and roger on turning their sore butts over to the police. Good news for you. When I had the body work done in Jan following the car port collapse, Merlin said that there were a lot of front fenders in the supplysystem
Sorry about your problems...but this is EXACTLY why I "themed" my VX with the skulls & crossbones...you touch...you die!
let the chanting begin..........mythbusters....Mythbusters.....MYTH BUSTERS!!!!
Must have been one of those sharp, square-edged water balloons. Check out the crease it made...
Glad it didn't hit a person! Could have been deadly. Or caused a concussion at the very least. Should buff right out of the VX though...
I dunno... I threw many a water balloon into a parking lot from a 4th floor balcony - hit many cars while aiming for the people hiding behind them - and never saw one cause any damage whatsoever. Could they have tossed something else and followed it up with a water balloon?
I've seen a wet roll of TP crush a hood.
No - I wasn't the throw-ee.
I was the target. Glad they missed.
Yeah - I can see that happening. With wet TP there would be a fair amount of mass and it wouldn't compress much - so all the momentum would be concentrated in the area of a roll of toilet paper. With a balloon, it seems the energy would be dissipated since the balloon stretches and then breaks. Looks like the PSI delivered would be limited by how stretchy the balloon is. If the balloon hit a concave area and thus trapped the energy of the mass of water I can see how it would make a dent but still it wouldn't have the psi necessary to crease steel. If it hit a convex shape like the crown of a fender it seems like it would scatter the water and dissipate the momentum (in addition to the crown shape being structurally stronger) so it wouldn't even create a dent much less crease the sheet metal like that.
I'm not saying this couldn't happen, I'm just saying he might want to look around and see if there was something else thrown because if there wasn't then that is one FREAKY water balloon accident!
I think all y'all armchair scientists might be missing an unknown here...
Did the person filling the baloons have a water softener in good working order???
I rather doubt it...![]()
Maybe it was a Water Grenade!
I can assure you guys it was only a water balloon, that crease in the middle is where the metal wrapped around the FRAME of the carThere are no scratches anywhere around the impact... and the area was free of any gel-like or otherwise soft things that could've been thrown. I'm just glad that I won't have to be convincing insurance that a water balloon did it.
.....Yeah I saw the same picture you did.
Slow..pro...went into detail.....
...I would say there was about a liter or less of water...at a rate of about...
....two pounds - max and that is saying this was a LARGE BALLOON....
Dropped from that height would do damage if it it was a solid.....
The fact that it is not a solid and the engery is spread over a wider contact area + the factor it hit one of the strongest points of metal -..
..I doubt it -
....Them saying they will pay for it..is as good as the paper it is written on.
Heavy water from a nuke reactor?
