After pulling my brakes apart this evening, the pads are shot on the front and rear.
As usual, the VX was never sold in the UK, so i need to know what model Isuzu to order the brakepads for? I would assume that its the trooper 2??
Anyone know ?
Anyone know ?
We have the same front and rear brake pads as a '91+ Trooper, a 98+ Rodeo, Rodeo Sport, Amigo, Honda Passport, and a '02 Axiom. Just make sure you get ceramic pads, which I believe were stock. They're the ones that last 96-128K km (60-80K miles) and have no visible brake dust.
My history with ceramic pads-
Rears replaced at 64K and 136K miles.
Fronts replaced at 80K and 159K miles.
The Isuzu part numbers for the brake pad kits are-
Front- 8-97035-257-1
Rear- 8-97035-266-0
Mark
Thats perfect. Thanks alot
Hi in the UK there plenty of genuine Isuzu pad sets on fleabay at the moment - you can use any of the following - trooper 97> , Frontera 98 > they are about the only UK versions that will fit
the genuine ones come with new anti rattle shims and grease - the vauxhall ones are after market unless you get the expensive ones
Oh yes and Monterey ones fit too
Best thing is to get in touch via pm or email - i'll let you have the full x ref
cheers
Steve
Thanks as always steve!! I ended up getting some pads from Milner Offroad for the Trooper USB25 which seam to fit fine. No anti rattle shims but i just put the old ones on the new pads.
I forked out and did to this what I did to my last Yaris and fitted 3G grooved and dimpled discs (machined Brembos) all round and EBC Greenstuff pads for the Frontera.
It stops. Quickly. But it will be even better when I finally get braided lines fitted.
I was £350+ for them but they were money well spent.
A
Hi Alan,
Any idea where you'll get the braided pipes from? HEL? I replaced brake pipes on a m/c which meant draining the whole brake system. Is that something that is relatively straight forward, as I'd also like to uprate them on my VX?
Kirk
I would guess SWB trooper '97 brake pipes would fit fine - unless you have a massive body lift -lol
cheers
Steve
Here ya go...
https://id211.chi.us.securedata.net/...roducts_id=295
Thanks Ldub.
Kirk, I don't know as its something I need to do too - its the missing link in my uprated braking system.
I need to replace my pads all round too - that's been a little under a year but they have been "well used"
EBC Brakes direct actually list the Vehicross - Clicky Linky
Hth,
A
My brakes are squeeling and VERY anoying. Think the damage to one of the discs is to blame so fitting new rear disks today
3Gs ftw... Everyone loves it grooved and dimpled!
Is that with new pads? Have you removed any lip around the outer edge of the old discs to stop it rubbing off the edges (gently tap the edge with a hammer all the way round - time consuming but...)? Copperslip all around the outside of the new pads to stop them catching? There's something to do with toothpaste too but I've never had to do it so I can't remember the details...
Loads of things to try before the expense of changing the discs.
A
2001 ISUZU VEHICROSS 3.5L 3475cc V6 FI (X) [6VE1] : Brake/Wheel Hub : Brake Pad
GUARDIAN / ONE SOURCE Part # 61580
Rear
GUARDIAN / ONE SOURCE Part # 61579
Front
CENTRIC Part # 30005800 {300 Series}
Rear; Shims Included
CENTRIC Part # 30005790 {300 Series}
Front; Shims Included
BECK/ARNLEY Part # 0871475
Front; Semi-Metallic
BECK/ARNLEY Part # 0881475D
Front; AXXIS DELUXE;Original Equipment Pad Material - Replace Original Equipment Semi-Metallic With Semi-Metallic Only
BECK/ARNLEY Part # 0881473C
Rear; AXXIS CERAMIC
BECK/ARNLEY Part # 0821473
Rear; PREMIUM;Original Equipment Pad Material - Replace Original Equipment Semi-Metallic With Semi-Metallic Only
BECK/ARNLEY Part # 0821475
Front; PREMIUM;Original Equipment Pad Material - Replace Original Equipment Semi-Metallic With Semi-Metallic Only
BECK/ARNLEY Part # 0881473D
Rear; AXXIS DELUXE;Original Equipment Pad Material - Replace Original Equipment Semi-Metallic With Semi-Metallic Only
BECK/ARNLEY Part # 0861473C
Rear; Ceramic
BECK/ARNLEY Part # 0861475C
Front; Ceramic
RAYBESTOS Part # PGD579 {Professional Grade; Organic; 2.300" X 5.420"
Front; Organic; Originally Equipped With Ceramic
RAYBESTOS Part # PGD580 {PG PLUS 1.660" X 4.320"}
Rear; Organic; Originally Equipped With Ceramic
BENDIX Part # D580
Rear CQ Ceramic; OE Ceramic
BENDIX Part # D579IQ
Front Import Quiet
BENDIX Part # D579
Front CQ Ceramic; OE Ceramic
BENDIX Part # D580CT
Rear CT Ceramic; OE Ceramic
BENDIX Part # D579CT
Front CT Ceramic; OE Ceramic
RAYBESTOS Part # SGD580C {Service Grade; Ceramic}
Rear; Ceramic; Originally Equipped With Ceramic
RAYBESTOS Part # SGD579C {Service Grade; Ceramic}
Front; Ceramic; Originally Equipped With Ceramic
RAYBESTOS Part # PGD580C {Professional Grade; Ceramic; 1.660" X 4.320"
RAYBESTOS Part # PGD579C {Professional Grade; Ceramic; 2.300" X 5.420"
RAYBESTOS Part # PGD580M {Professional Grade; Semi Metallic; 1.660" X 4.320"
Rear; Semi-Metallic; Originally Equipped With Ceramic
ACDELCO Part # 17D579 {#18029128}
PAD KIT,FRT DISC BRK Durastop North America Only; FOR DURASTOP CERAMIC RECOMMENDED DUE TO OE VEHICLE PARAMETERS
ACDELCO Part # 17D580 {#18029129}
PAD KIT,RR DISC BRK Durastop North America Only; FOR DURASTOP CERAMIC RECOMMENDED DUE TO OE VEHICLE PARAMETERS
ACDELCO Part # 17D579C {#89056370}
PAD KIT,FRT DISC BRK DURASTOP CERAMIC; FOR DURASTOP CERAMIC RECOMMENDED DUE TO OE VEHICLE PARAMETERS
ACDELCO Part # 17D580C {#89056372}
PAD KIT,RR DISC BRK DURASTOP CERAMIC; FOR DURASTOP CERAMIC RECOMMENDED DUE TO OE VEHICLE PARAMETERS
WAGNER Part # ZD579 {QuickStop Brake Pads}
Front
WAGNER Part # ZD580 {QuickStop Brake Pads}
Rear
CENTRIC Part # 10505800 {Ceramic}
Rear
CENTRIC Part # 10505790 {Ceramic}
Front
MONROE Part # DX580 {Monroe Dynamic Pads
Rear
MONROE Part # DX579
Front
MONROE Part # CX580 {Premium Ceramic Pads
Rear
MONROE Part # CX579 {Premium Ceramic Pads
Front
CENTRIC Part # 10005800 {100 Series}
Rear
CENTRIC Part # 10005790 {100 Series}
Front
WAGNER Part # PD579 {ThermoQuiet Brake Pads}
Front
WAGNER Part # PD580 {ThermoQuiet Brake Pads}
Rear
ATE Part # AT579 {Disc Brake Pad}
Front
ATE Part # AT580 {Disc Brake Pad}
Rear
AKEBONO Part # ACT580 {ProACT Ultra Premium Ceramic Pad}
Ceramic; OE Ceramic; Rear
AKEBONO Part # ACT579 {ProACT Ultra Premium Ceramic Pad}
Ceramic; OE Ceramic; Front
RAYBESTOS Part # ATD580C {Advanced Technology
RAYBESTOS Part # ATD579C {Advanced Technology
WAGNER Part # EC579 {EDGE Brake Pads}
Front
WAGNER Part # EC580 {EDGE Brake Pads}
Rear
But I would just get some OEM ones![]()
Bloody cheapskate!
