Quote Originally Posted by Cobrajet View Post
I've used Mobil1 M1-104 filters since my first oil change, and I've now got 117,500 on my VX. I did a Google search a few minutes ago and found a thread on the Acura MDX site where a guy says he was able to install the longer M1-105 filter on his MDX. I've got my last M1-104 sitting on the shelf, so I may try to find an M1-105 for my 120K tuneup.
Just as an FYI - I just did my first oil change on my 60K mile VX, and installed the M1-105 filter (also filled up with slightly over 5 quarts of Mobil 1 10W-30 Full Synthetic). Seems to be fine, with no leaks, though the "O-Ring" style gasket and larger diameter concerned me initially. Also, the larger diameter puts the filter w/in 1/4" of the harmonic balancer; I don't think this will be a problem though, since even if the engine "torqued" upon heavy acceleration, it SHOULD torque AWAY from the filter. Has anyone else gone to the larger Mobil 1 M1-105 filter yet?
