Results 1 to 10 of 10
Thread: A little confused
    Mar 2008
    1999 (2001) Radiant Red 157/175 "lil pwny"
    A little confused
    Ok I am a little confused, I own a Radiant Red 157/175 VX. All the 175’s I have seen are marked as 1999. But my import plate shows mine as a 2001. Would this be because it was imported in 2001 and thus plated as such?
    My last 4 numbers of my vin is 1858. I tried to search the forums for a link I once saw that shows year production to vin number but I have not located it.
    Any help would be great as I want to make sure that I have my beast insured properly
    Cheers
    Thats a point the 175ltd that i have listed in the for sale section is
    Registration status: Active
    Vehicle usage: Private Passenger
    Cause of latest registration: Used
    Date of first registration in New Zealand: 2004, January 9th
    Date of last registration: 2004, January 9th
    Registered overseas: Yes
    Date of first registration overseas: 1999, Apr
    But yea :S
    um
    See if you can find a aussie one of these .
    http://www.carjam.co.nz/
    2001, Proton Yellow, #0580
    I've found too that a lot of the original docs for title, etc don't always follow the vehicle once it passes from it's original intended country elsewhere.
    -- John
    Jun 2005
    01 Dragon Green VX 1286
    V--what is that digit.. if its a number it will tell you what year your VX is...
    xxxx xxxx
    I am gonna assume its an 9 for 99, which is what all the 175s where
    Jeff
    Post pics, mate!!!
    01, LineX tan/black, 1055
    Not sure about JDM, but if your climate control is automatic,ie pick a temp and forget, then its an 01, if not, its pre-01.
    Mar 2008
    Post pics, mate!!!
    You just want to see car porn :P i will post pics over the next couple of days, heading up the mountians so will get some action shots.
    Re the climate controls, mine is not set and forget and going on other imformation it appears i have a 1999 vx, plated 2001 for the Australia market.
    cheers guys
  1. Lifts & wheels Dazed and Confused
    By Pigpen in forum VX Talk...
    Last Post: 07/21/2005, 06:13 PM
