Results 1 to 14 of 14
Thread: Just How Deep Can I Go ?
    2001, IronMan White, #440
    You might want to be careful about the mud too. There is a sensor that moniters everything and it is located somewhere on the bottom front of the VX. If it gets muddy it starts to shut the vehicle down little by little.
    This happened to Lisa. Luckly, her VX was still under warrenty underwise it would have cost her thousands to fix.
    Peace.
    You might find this thread to be good reading.
    http://www.vehicross.info/forums/sho...hlight=fording
    You boys who like to play in that slop kill me!!! I hate the mud! I hate driving in it, I hate getting stuck in it, and most of all, I hate cleaning it off my VX! I'll take those red sandy banking Moab trails any day over the black sludge!!!
    PS - If you do a lot of mudding, you are going to have to get your wheel bearings re-packed with grease more regularly....
    Dec 2003
    Former Owner 0216
    Remember when going through deep water to push it.... don't plow it.
    May 2008
    99' White Ironman 30,000 miles
    I'm sorry, I'm sorry.
    I've just got to say it!
    "That's what she said"
    2000, Ebony, VX, 0370
    Thanked: 12
    I'm glad you said it because I was thinking it.
    01, LineX tan/black, 1055
    I have had mine in mud above the tires, almost above the cladding, no problems, just clean it out afterwards right away. Then check all your fluids and whatnot. I would definitely agree that its at your own risk, and to be careful about bearings and stuff. As a disclaimer, mine is not a required daily driver, so I am willing to risk a little more and I never go out alone, only with at least one other vehicle and mostly within 20 miles from home.
    Quote Originally Posted by Luninox View Post
    Yeah, but, shouldn't it be "that's what he said?"
    '99 Ironman, 0992
    Peace.
    As the others have said, it's a bit of a crap shoot whether you have problems or not. The main issue is that the alternator is mounted low on the engine so it doesn't take much depth to put it under water/mud. The electrical system is as sealed as much as any other normal vehicle. Most of the water related issues reported had to do with the alternator and that is what died on Lisa and had to be replaced.
    Dec 2002
    '01 Ironman
    As long as the air intake stays above the water your pretty good, ya maybe lose an alternator or a sensor, but who cares? Nothing $200 and an hour won't fix, have fun!
    Sometimes when fording something deep I get a sensor wet and it seems to stay in 3rd gear, all I have to do is turn it off then back on and it works just fine again.
    Just keep up with maintenance: fluids in differentials, tranny, and wheel bearing grease and you should be fine, you don't need to change the fluids everytime or anything just keep up with a higher maintenance, and if you think the water got in something then change out the fluid ASAP.
    Check my gallery for "swimming" and I wouldn't advise to go that deep but that is about how deep you can go. 10" is a little puddle, c'mon you own a Vehicross, I would say 20-24" would be a good safe depth. Remember to go slow when crossing water or you will build wake in front of you and that 24" can turn into 36" real quick.
    Quote Originally Posted by AlaskaVX View Post
    oh ya!
    your pictures are some of my favorites...it makes your VX look really badarse...
    i have had my VX above the headlights in water, but i dont suggest it...mine was definately done by accident...
    the water was usually about top the tire depth but for some reason it went up about a foot, at least
  1. How deep is too deep?
    By MustangO4 in forum VX Talk...
    Last Post: 01/27/2008, 07:28 PM
  2. For the diesel-head with deep pockets...
    Last Post: 01/15/2008, 08:03 PM
  3. Hell's not deep enough for Michael Vick...
    Last Post: 09/14/2007, 11:19 PM
  4. Deep dent from a Harley Sportster
    By Dino in forum VX Troubleshooting...
    Last Post: 07/12/2007, 08:39 PM
  5. Recaro Leather - deep scratch
    By Maugan_VX in forum VX Talk...
    Last Post: 09/21/2005, 01:48 PM
