I was getting rather aggravated over the poor rearward visibility so I started looking at head units with a monitor so I could install a backup camera. Of course the fact that the CD changer would jam often didn't hurt this decision either.
I ended up getting the Jensen VM9412 it's a CHEAP (I paid $300 through amazon.com) simple CD/DVD headunit, it's Satellite radio ready, iPod adapter ready and you can even upgrade it with a NAV unit down the road... the Jensen 101 goes for $150-$200 and you can stash it under your dash somewhere and it adds full NAV to the head unit. and of course inputs for a reverse camera too.
The best thing for VX users is that you can program the screen to stick out further from the unit to give you extra room. It has two mounting holes and going with the set further back, along with programming the screen to stick further out I'm actually able to get a comfortable back angle Without the screen even hitting the dash.
it sticks out a bit more than the factory stereo because of how I mounted it but it doesn't stick out so much as to be obnoxious, it also looks like a cheap generic CD player when it's closed so it doesn't draw attention
Open I have the screen set to stick out a bit away from the unit, this allows me a nice back angle. It's not the most feature filled or best sounding unit but I actually like the CD player interface better than the $700 double din unit Kenwood that I have in my 240sx.
it's hard to tell but the screen isn't even touching the dash... If I wanted to I could even lean it further back.
I'm pretty pleased wit this unit so far, I'm still looking at my backup camera options (so if you have any recommendations let me know).
I posted this because I'm always seeing threads with people who want to know how to fit a video unit in their VX and this is the only flip out unit I've seen that could actually fold out with a comfortable angle and not hit the dash.
I should note that I had to trim up the dash garnish a bit. the screw hole above the stereo I took a dremel and cut off the bump on the inside, I might not have had to but it made things easier, I probably wouldn't have been able to get the screw back in anyway because of how far the stereo sticks out. You can't even see it from the outside. Also the opening for the stereo was literally a hair too narrow so I took a file and filled down the left and right sides, if you put the stock stereo back you wouldn't even be able to tell that's how minimal I had to file it down. took me less than 5 minutes to do both of those things. Other than that it was a standard stereo install, just wire up the harness and screw it in place.
I swapped the lower unit out with a simple din pocket so I have some place to put my CDs or my Zune and it frees up the arm rest for other stuff.
