Results 16 to 30 of 37
Thread: Os' VX: The Arrivaling
  1. #16
    Man, that thing is ugly! Send it back for a refund!
    Enjoy.
    Quote Originally Posted by Osteomata View Post
    - Mirror light power cord! Ah, got it that makes sense.
    Don't feel bad. The salesman at the dealership I bought my VX (new) from didn't know what it was either.
    Welcome to the addiction!
    My VehiCROSS
  3. #18
    Jan 2008
    I still have my fuzzy hole!
    This should be good ;-)
    Best,
  4. #19
    '01 Proton #0317
    Quote Originally Posted by VehiGAZ View Post
    That's not right - the option button does not work with the alarm system. It was originally supposed to work with an optional receiver you connect to your garage door opener wires in order to open your garage door (but it is no longer available, I believe). It needs the DC voltage from the garage door opener wires in order to power itself and receive the signal from the remote.
    Alittle off topic, but I believe this option IS still available; in fact, the "system" still shows 9 (now 8!) available at ~$105.00. I just ordered one from our friend Merlin; not so much for my garage door, but for the gate to our gated community - the "opener" that they give ya' for THAT dates to 1985 - it's the size of a large paperback! I'll let everyone know how that install goes...
    On edit - I just read previous threads about this; apparently the "unit" they ship you installs in your garage, not in your VX - guess I'll be replacing my garage door opener and NOT my gate opener after all...
  5. #20
    hatch popper connected to 2nd button on remote
    Vehigaz- thanks, you may have just saved me some time & money trying to get my audio guy to wire the hatchpopper to the remote.
    Here's the link to thread where "Raque Thomas" got it to work:
    http://www.vehicross.info/forums/sho...+popper+remote
    Does anybody know if this does really work??
  6. #21
    Dec 2004
    Ahhh!!! OK, I see where you are going VX KAT. Yes that mod will work - but it does not use the option button on the fob. Etlsport should be able to tell you how to do it - he;s still around and he did this mod a couple of years back.
    The alarm module has two outputs - one for one press of the button, and anotheroutput for the second press of the button. Normally the driver's door unlocks on the first press, and the passenger's door unlocks on the second press. That mod (if I understood it right) will unlock both doors on the first press of the unlcok button, and will actuate the rear hatch popper on the second press. I was thrown off by the discusssions of what happens with the door locks and such when the car is running, but I am pretty sure that's how it works.
    Didn't mean to contradict you - turns out we were both right! :-)
  7. #22
    Washer problem...
    Lift hood , pull apart plastic hose connectors either side of washer feed split
    where it routes tube to washer nozzles
    These are in fact One way valves , ball bearing style , and get clogged up.
    Clean em out...make sure you put them back in the same way!....this solved my issues.
    Hope it helps
    yep thats right, first push of the unlock button will unlock the doors, second one will pop the rear hatch
    if the key is not in the ignition the unlock button on the door handle will pop the rear hatch too
    if the key is in the ignition, you have to use another trunk release button you install somewhere else to open the hatch
  9. #24
    Jan 2008
    1999 Astral Silver 0481
    New VX member
    Is deffinetly good to be part of a supportive family isn, t it ?
    Nice looking proton though OS
    After the new cladding is installed & the whole VX well detailed you'll get even more in love with.
    Oh ! Be prepared for all those VX moments from now on OS people turning their heads & jaws breaking looking faces
    Dakar was just the begining.
  10. #25
    Feb 2009
    2001 Proton Yellow VX 0938
    VehiGAZ: I did not mistake the option button for part of the alarm, but I did take from VXKAT's post that the option buttion could be made to work with the rear door popper. Is this not feasable? Cause that is really what I want it do do.
    WormGod: "Man, that thing is ugly!" Bet that's not what you told the chick who offered you $8K for yours!
    Snowtrooper: What, you don't find it perfectly natural to talk about one's fuzzy hole? Mine is velvety. It made it through the wilderness. Somehow it made it through. Didnt know how lost it was, Until Isuzu. It was beat, no rear seats. It'd been had, it was sad and blue, but Isuzu made it feel, yeah, made it feel...Shiny and new. Chorus: Like a virgin. Yeah, I said it.
    JoFotoz: Thanks for the detailed squirter check guidance, I'll get on that one with my oil change this weekend.
    Gussie2000: You ain't kiddin, I can't wait.
    - Os
  11. #26
    technically you could make the rear door popper work on the option button... but only if you bought the module, either modified it to work on 12 volts or put a 120 volt outlet in your vx, then rewired it to activate a relay/solenoid when the option button is pressed
    or you could just do what raque thomas did (and i did).. rewire the existing wiring so that the first time you press the unlock button, both of your doors unlock.. then the second time you press the unlock button, the rear door pops
    the only downside to this mod is if you press the unlock button by accident, you either have to leave it and trust the 30 second re-lock feature to work or pop the rear hatch, close it, and lock the doors
  12. #27
    2001, Proton Yellow, #0580
    I wired the rear door popper to the third button on my remote. There's a tranny circuit you use to keep the rear door from activating when in anything but park.
    -- John
  13. #28
    Dec 2004
    Quote Originally Posted by johnnyapollo View Post
    -- John
    This is interesting...
    John, do explain, please - especially the part about the third button (since the OEM alarm fob only has two buttons on it. ). Do you have an aftermarket alarm?
    And what transmission circuit did you use for this? That's brilliant!! You don't know how many times I have accidentally popped the rear hatch reaching for the stereo controls while in motion!!
  14. #29
    Jan 2008
    I guess he must have an aftermarket alarm
    About the transmission circuit he's probably talking about running a neutral wire to the park position that only engages when the shifter is in park & the 12 current voltage running thru that circuit allows the alarm's module to receive the remote's signal
  15. #30
    Dang...I thought getting the hatch popper button would be next on my list....sounds like it's going to cost too much for me to have my audio guy do it.
    VehiGaz, no problem contradicting me, quite the opposite, thanks to you (and all the others) for helping me better "understand"......no, scratch that......for helping me see that I won't be getting a hatch popper button working on my remote any time soon!
    BTW, on my OEM remote, the 2nd button says "hatch", does yours say "option"? Mine is an Isuzu OEM remote, but I bought it used, so it may not have gone to a VX I guess.
