After purchasing the Proton on ebay, and tracking my her from NY to FL on the DAS auto shipper website, I finally took possession today. Cut out of work early, caught the Tri-Rail (another first for me!) from MIA to Fort Lauderdale Air Port, taxi the last few miles, and arrived at DAS' drop off point:
And spotting her in the lot:
What a painless process: show ID, inspect, sign and drive. We are headed home:
What a fantastic start! My first four wheel drive ever, my first truck/SUV ever, hell I haven't had more than 140hp since 1990. I am so not used to sitting up so high in traffic, so not used to the ready power.
The seller of course left her nearly empty (no surprise) which gave me my first opportunity to fill her up, check the oil, and set the trip meter. I was suprised that there was no tag on the VX at all, not even a dealer temp tag. I drove it home bare, worrying all the way about getting pulled over. Tomorrow I will remedy that.
As the seller made clear, the right front bumper and lower right front signal are damaged, but those parts are in route. The backseat is also missing, but VX KAT and I are working to resolve that to our mutual benefit. She has agreed to give it to me in exchange for my heartfelt appreciation. And some cash.
I bought this site unseen, and I am happy, or rather relieved, with the result, but one can't expect perfection, and there are a few minor issues about which I was not aware:
- The PO jacked the emergency handle, I guess it wore badly or something, cause he appears to have taken a dull carving knife to the rubber/plastic coating of the handle, stripped it part way down, and stuck on a really ugly aftermarket fake CF (and not a good fake) handle. But only the top half of the handle, so it comes off easy, and the bottom is raw cut plastic/rubber.
- He also appears to have drilled a hole in one of the bevel switches, the right most switch of the row of three located to the right of the steering wheel. I am looking at the manual, and I can't tell what the switch was for. Anway, drilled a big hole in it, stuffed some rubbery material arond the raw edges, looks like some kind of wire was supposed to go in there.
- The rocker switch right next to it has a very tiny led light cover on it, is that stock? Looks modded.
- There is an insulated wire, curly like a telephone cord, sticking out of the front of the head liner just above the rear view mirror, it leads down to the mirror bracket, and .. I can't tell what it does then. Did not have time to investigate, have to go re check it.
- Whatever is supposed to be to the right of the cig lighter is missing. Just a rectangular hole with a bracket, looks like it was supposed to be a coin holder or something?
- Tires are nearing the end of their safe service life.
- Passenger side winshield squirter does not squirt. I will have to check the squirting equipment for maximum squirtyness.
Tomorrow: Florida registration and tag
Thursday: Oil and PCV change
- Os
