Results 1 to 12 of 12
Thread: Turn Signal Problems....YES..I searched!!
    Turn signals and Hazzards dont work...
    Fuses OK
    Bulbs OK
    Is this a relay problem (behind fuses in cabin?)..if so please explain!!!????
    I'm Ok on mechanics..lousy on electrics!
    Any input greatly appreciated!
    relays are cheap and easy to install my friend....
    probably around $2.50 a piece....
    if you can get me the 'relay number' off of the relay i will find out how to test it for you, (or you can just replace them)...
    should be easy to replace, unplug and plug in new ones...i will look under my VX later to make sure though...have you found the location of the relays?? if not i can probably find them for ya...
    I'm not even sure it's the relay....
    ...was hoping some one could tell me if it is!!
    there is a simple electrical way of looking at turn signals/emergency flashers...
    12v to the ignition- ignition to the switch- switch to the fuse block- fuse block to relay- relay to bulb- bulb to common grounding point- common grounding to battery.
    so, ignition is working so that isnt the issue, if the fuse is recieving power when the switch is on, then the switch is working, if the fuse is good then next is the relay, test the voltage at the bulb to see if the relay is working, if there is no voltage to the bulb, but there is voltage at the fuse (on both sides of the fuse) then its a relay
    try that and let me know how it works for ya
    try your hazard light switch too, if that goes or the connection is loose, nothing will work
    ya good call, the hazard light has constant power to the batt. whether the ignition is on or not... take a multimeter and test the input and the output of the hazard switch...
    once again, if you dont know how to do this, ill pull mine apart and tell ya what wires to test...
    Thanks Guys...
    I'll test the hazzard first , and we'll go from there!
    May 2002
    2000, Proton Yellow, VX, 0584
    Flasher relay is behind the D/S kick panel. Hazards are on their own circuit.
    Scott / moncha.com
    so it sounds like the flasher relay to me if they hazard is on its own circuit...
    that would cause either (the switch or the hazards) to give voltage to the 87 side of the relay, and no output to come out of it...
    One or several too any Rums to look at it right now...
    ...I'm enjoying the sunshine at 6;15.
    I come alive when the clocks change!
    Will check it out Moday/Tues...and get back to you.
    Thanks for all the inpurt.
    Jo,
    you live in California....no one uses their turn signals there!
    no problem, i understand lol, if i wasnt working today i would have had too many rum's too...its freakin gorgeous today in colorado (like 65 degrees)
  1. turn signal relay ??
    By orion in forum VX Troubleshooting...
    Last Post: 07/13/2014, 10:23 AM
  2. Turn signal on when braking??
    Last Post: 11/19/2012, 08:08 AM
  3. turn signal help
    By dsallade01 in forum VX Troubleshooting...
    Last Post: 06/28/2011, 08:44 AM
  4. Turn Signal Lens
    By SomeBeach in forum VX Talk...
    Last Post: 07/01/2009, 08:05 AM
  5. Water in turn signal.
    By tomcat837 in forum VX Troubleshooting...
    Last Post: 04/18/2004, 08:33 AM
