Whatever, you can't mess with the original intergalactic ladies man.
Nice job on the swap...gives us another option besides Trooper's! If the '02 Axiom you got the donor from has "drive by wire" throttle control...I'm guessing that's probably the killer on why the ECM didn't work.
Yes, only the '04 Axiom has D.I. Didn't know about the Rodeo though.
There we go I knew only the 2004 had it. Yes the 2004 Rodeo has the same set up. Before my wife bought her Explorer I was trying to locate one of these and tempt her into getting it.
The 2002 engine did not have the DI to begin with, so you did not lose it if you did not have it anyways.
what is all this oil consumption business i read about, and when does it usually start happening? mine stays perfectly level between oil changes, you're all making me very nervous haha. good job on the swap. i've seen a similar coffee table made using a ford probe engine...pretty cool for a garage, or shop. wouldnt put it in my living room
Ok, now, the KEY here though on the '02 Axiom... it HAS to be an Axiom with the 8th digit in the VIN is an 'X'... AND manufactured BEFORE MAY of '02... after May it was a different tranny so it won't match up... it still may have the 8th digit 'X' but after May it was a different transmission... aisin I think... what is the tranny on the VX... I forgot, and too lazy to look it up...
No '03 Axiom will fit the VX, BTW
There we go. Now thats good info.
The 2004 is alot differ. than our VX set up.
I would like to ask you, are you using regular motor oil or synthetic?
My VX has been a voracious oil burner since I bought her with 25k. However, I switched to synthetic right away, and there is a part of me that still wonders if synthetic oil is the reason why VX engines start burning oil, but this is just speculative on my part due to not knowing the stats....
I'd say no...I bought my VX new (only owner) and she's been on synthetic (Mobil 1) since I did the first oil change @ 3,000 miles. Now have 86,400 miles, and everytime its due for oil change...dipstick only shows a deficit of like 1/4th of the total length between full & add (or less).
I refer to that amount as 1/4 quart as I believe you're down 1 quart if you are @ the add line.
Since I don't drive MY VX much th the due date comes before the amount of miles driven on the "Oil change sticker" reminder thingee. I noticed when my VX was Garaged parked I did not need to change or add Oil as much as most recently its been parked outdoors.
Does the Weather elements have something to do with oil burn?
The Bantan's Relm
Gallery
Myspace Page
