Ok guys I'm doing the 02 Axiom Engine swap. Do I need to purchace anything besides the used engine, maybe a wiring harness or anything else?
The Bantan's Relm
Gallery
Myspace Page
Great!!
Use the Axiom block and heads, the VX wiring harness and intake and injectors and you'll be Golden. Everything else is the same... even maintenance later... Oh, and if you buy the Axiom engine and it has the intake on it... you can take the FPR and the EGR off and use them on the VX intake... they fit and would be newer than what you have on the VX.
If you have any other questions, don't hesitate to ask.
Good Luck!!
We sit together, my VX and I, until only the VX remains.--Iamironman
Thanks, brother from another Mother.
I'll keep ya posted.
I got a rod knockI'm pretty sure i do. going to bring the car to mechanic tomorrow to confirm. I found trooper's engine for $1,700 and labor was quoted as $1,000. plus something else that comes up at such works - i'm looking at $3,000. most likely i will not be able to afford such an expense. even the engine itself... but if i'll come up with money for the engine, isnt it pretty straight-forward procedure? i do realize it is time-consuming, requires special tooling, engine lift, etc, but what are the hardstops i can face while replacing the engine? i shall highly appreciate any inputs. and im very interested in axiom engine in particular. i'm trying to brainstorm the procedure and seeing that beside the engine i shall need numerous gaskets, something tells me i shall be needing new bolts, if im going to deal with the VX intake on the top of axiom engine...
is there anybody insterested in 1999 Ebony with 111k miles on a body? nice 17" rims with yoko geo is the only mod. that is my worst case scenario, and i have a week to make a decision
