Page 3 of 3 FirstFirst 1 2 3
Results 31 to 36 of 36
Thread: How loose is your steering??
  1. #31
    Sep 2009
    1999 Astral 1052
    I looked at mine late yesterday and talk about hard to get at there is not much room to use any wrench and too tight for a rachet. I went to get my liquid wrench to see if that will help loosen it up but could not find it so I going to get a can today. It looks like it would be really easy if you remove the fan shroud, does anyone know if that is true?
  2. #32
    Feb 2004
    '01 Ebony #0830
    Talking Did it!!!
    I just did this adjustment this weekend... Holy cow what a difference!
    No need to remove the fan shroud. I doubled-up (end to end) two combination wrenches to make a long, almost 2 ft long box wrench. Worked like a charm. I only had to turn the center screw from about 2 o'clock to 3 o'clock until it stopped, then re-tightened the lock-nut.
    VERY happy with the result of this.
    Hey Jim (99VC), you may want to do this on yours. I remember it had a little slop when I owned it. VERY easy adjustment. Took about 2 minutes... most of which was getting the tools out of the box.
    ---JIM---
    SilverBullet75
    Formerly: '01 Ebony VXSTLTH
    Now: '08 Saab 9-7x Aero 6.0L
  3. #33
    Sep 2008
    2000,Kaiser silver,VX,0576
    I've got almost no (or very little) slack in mine. Besides T4B won't cut me any.
  4. #34
    Must be the wide bucket ... provides a stable platform.
  5. #35
    Sep 2008
    To quote a former bestus bud of mine, "I have no response to that."
  6. #36
    Jun 2003
    2001, Black 0793
    Thanks to the forum for saving me another repair.
    My steering had gotten progressively loose and looser until it was scary. As usual, I searched the form and found a solution.
    This fix works very well...that is once I let PB penetrating catalyst soak in the nut for a full day and then picked up a Craftsman universal ratcheting flex wrench to lossen the nut..quite a tight space to work.
  1. Loose steering wheel - Need help.
    By jtirado in forum VX Talk...
    Last Post: 04/02/2018, 03:34 PM
  2. Transmission Loose?
    By ipd in forum VX Troubleshooting...
    Last Post: 01/31/2016, 07:44 AM
  3. Loose steering
    Last Post: 12/19/2004, 10:58 PM
  4. steering loose/dealer blames tires
    By dutchie in forum VX Troubleshooting...
    Last Post: 01/02/2004, 10:41 AM
  5. Loose Steering
    By Leah in forum VX Troubleshooting...
    Last Post: 09/23/2003, 07:42 AM
