Originally Posted by
JAMAS
How do I do that?
if you wanted to get more of an 'offroad' look then you could buy the OME springs for the rear...and then all you have to do is crank the torsion bars up front...
if your trying to keep the 'stock' look then you need to have it adjusted back to stock...
its just a cheap, easy way to make your VX look much more aggressive....
search for lift or something along those lines and you will see tons of threads and walkthrough's on how to do it...
