Results 1 to 15 of 42
Thread: Bump Stops
JAMAS Bump Stops 02/17/2009, 02:22 PM
ZEUS The rear bump stops? The... 02/17/2009, 02:39 PM
JAMAS Rear 02/17/2009, 02:47 PM
ZEUS If you are riding around on... 02/17/2009, 05:06 PM
pbkid or you could raise yours VX... 02/17/2009, 06:17 PM
Ldub IIRC, & it's been a while... 02/17/2009, 10:42 PM
JAMAS How do I do that? 02/18/2009, 10:34 AM
    1999, Ebony Black, VX, 1614
    Bump Stops
    Are the bump stops supposed to be making contact when the VX is parked(key out of the ignition) or should there be clearance underneath the bump stop when it is at rest?
    Thanks.
    The rear bump stops? The front has two pairs/types of bump stops and the rear has one pair/type. Generally, in stock form, the rear bump stops seem to be within an inch of the axle when at rest... touching though sounds like potentially mild sagging of the springs, to me... or maybe a missing spring isolator (?). The front droop bump stops may be touching the upper A-arm if the torsion bars were cranked up enough, which would be bad. If the VX was lowered enough, the lower A-arm could be touching the rebound bump stop, which would also suck.
    Rear
    Rear bump stops. I just double checked they are definitely touching.
    Its parked in my driveway, at a very,very slight angle(front is a wee bit higher, back is a wee bit lower, wee bit)
    Should I be concerned?
    Thanks!
    If you are riding around on your bump stops, you can expect a rougher ride and in some situations it may be dangerous. Some VXer's in the past cut down the bump stops so as not to ride on them but offset wheels and/or bigger tires could cause the tires to rub the wheel well after performing this action. Go over some speed bumps and stuff at an angle and with some speed to see if the VX gets pitched around because of the extra stiffness. I figure the VX rides on the outer bump stop during hard cornering anyway, so I doubt it is a problem... but like everything else you read, take it with a grain of salt. I imagine someone on the board has some stock springs collecting dust, if it makes you uneasy, you could swap out perhaps. As a lame guideline, the VX in stock form sits with a rake toward the front - so the rear end is higher than the front.
    or you could raise yours VX ever so slightly (like 2") so you dont have to worry about it....costs about $150 and 2 hours of your time...
    IIRC, & it's been a while since mine was stock, on level ground, there was only about 1/4" of clearance between the rear axle & the bump stop...
    Front raised
    I just spoke with the previous owner. He said that the front was always raised a little higher. He thinks that maybe the torsion bar was cranked too tight.
    Does that make sense? If so, how do I go about correcting that so my VX is level again. Should I just go to a suspension place and have them look at it?
    Thanks for the help. I just purchased yesterday and have been going over everything with a fine tooth comb making sure I made a good purchase.
    How do I do that?
    How do I do that?
    if you wanted to get more of an 'offroad' look then you could buy the OME springs for the rear...and then all you have to do is crank the torsion bars up front...
    if your trying to keep the 'stock' look then you need to have it adjusted back to stock...
    its just a cheap, easy way to make your VX look much more aggressive....
    search for lift or something along those lines and you will see tons of threads and walkthrough's on how to do it...
  1. rear bump stops
    By vxfocus in forum VX Modifications...
    Last Post: 10/13/2012, 08:59 AM
  2. Bump stops
    Last Post: 09/13/2012, 03:29 PM
  3. Bump Stops (again)
    Last Post: 03/03/2011, 02:00 PM
  4. Rear Bump-stops
    By kelvin in forum VX Troubleshooting...
    Last Post: 05/31/2007, 02:23 PM
  5. Bump Stops Aid Handling?
    Last Post: 05/05/2004, 10:48 AM
