Results 1 to 6 of 6
Thread: OPTIMA Blue Top battery for RVs
    I know many are familiar with or using the Optima Red or Yellow Top in the VX, but do any of you have RVs where you use the Blue Top? We're looking at the D34M. Seems pretty outstanding for an RV application.......Maintenance free, zero fumes, multi-positional, long dormant shelf life, and a bit lighter than most batteries?
    '01 Proton #0317
    Concord Lifeline AGM's - been usin' 'em for several years now (I have 3 80 amp/hour house batteries in my RV) and they work great! Talk to Randy at BestConvertor.com - a great guy on top of it!
    http://www.bestconverter.com/
    No offense to those on the board that are "high" on the Optima products, but these will BURY 'em!
    And for your chassis batteries (including the VX) it's impossible to beat the new Sears Platinum DieHard line of AGM's. I've got one of those in my RV, and WILL be putting one in my VX!
    i have die hard in my isuzu and redtop in my teg....redtop in my teg because i run large, large amounts of wattage through my sound system...
    when i had my motor rebuilt they automatically put a die hard in my VX, havent had any problems so i havent changed it since...
    i will say though, i have KILLED my redtop like 10-15 times to the point where it wont even click and i attach jumpers and it seems like its almost instantly charged and doesnt lose it...
    ive got a d34 blue top in my vx... pretty flippin awesome.. it lasts forever.. i can run my system about 3 hours very loud and still start the car afterwards no problem.. left my interior lights on for a day and a half once too.. no problem starting
    My experience is with the Optima Yellow D34/78 model.
    I have just under 7 years in my wifes’ Safari Van in Oregon. I have 5 years on a red top in the VX. Fingers crossed.
    The yellow is a deep cycle and seems the same as the blue marine battery in performance. The marine has a small additional post next to the normal top posts. I have a blue D34 with offset coils in my boat. I like the top and side post models, so I can swap into anything when others need help. Only the red and yellow models have this option.
    The deep cycle models have more matt gap between coiled plates and can take “many” deep cycles without performance loss. The red has a thinner matt gap and can take at least 12 deep cycles with no harm. A thinner matt means more room for metal plates in the same package, so more starting amps. It’s a trade off.
    The yellow D34/28 has 75 amp hours.
    The yellow costs $170 plus $32 shipping on EBAY. I can pick up and save $32.
    The yellow is 6.9 x 10” and weighs 43 lbs.
    www.optimabatteries.com
    The Lifeline model GBL245 comes closest in size to the usual size at 6.8 x 11.1”, and weighs 58 lbs. Fit could be a problem.
    The cost is $247 plus shipping. A larger size and weight has a higher amp hour rate of 80 amp hours.
    Roy
    '99 Ebony VX #0038
    I give a big thumbs down on the Blue Top Optimas. For the past several years, my VX has become more of a weekend vehicle than a daily driver, so I thought it would make sense to purchase a battery designed to hold a charge for a longer period of inactivity. The Blue Top was supposed to be the best available.
    Apparently quality control has dropped considerably because I've heard many great things about Optimas purchased over 5 years ago - many are still in use today and working out great. My experience has not been so good - my first one died after a little over a year, and was replaced under warranty. The second one died a little over a year later, shortly after my original two year warranty ran out so I decided to go with an Autozone Duralast. This battery also seems to die on me in the dead of winter, every winter, but Autozone's 5 year warranty gives me a fresh, brand new battery every year at a much better price. So do the math - two batteries in two years for what, about $130 (Optima) vs. five batteries in five years for about $80 (Duralast). Same reliability at $65 per battery, or $16 per battery? I'm in the Zone.
  1. Optima Battery Holder
    Last Post: 05/17/2010, 06:05 AM
  2. optima battery
    Last Post: 12/26/2007, 04:41 PM
  3. Optima Battery
    By TechnoPope in forum VX Talk...
    Last Post: 07/27/2006, 09:58 AM
  4. Optima Red Battery
    By tomdietrying in forum VX Modifications...
    Last Post: 07/18/2004, 09:36 PM
  5. Optima Red Top Battery
    By EclipseGSX in forum VX Modifications...
    Last Post: 11/28/2003, 11:39 PM
