Results 1 to 8 of 8
Thread: Removing Exterior Rear View Mirror
    2000, Ebony, VX, 0370
    Thanked: 12
    Does anyone know how to remove the actual mirror from the rear view mirror assembly? I can get the whole assembly off, but I can't figure out how to get the glass part, itself, off of the assembly to access the guts. I would like to keep the glass intact during this little operation.
    Guesses, opinions, experience?
    I'm not sure, but isn't it held on with some industrial strength adhesive? Might be hard to remove without busting the glass....
    I have no experience with this (but need to for a similar operation on the TLC). Try stopping in at your local glass shop & see if they'll give you any pointers.
    Jun 2007
    2001, Proton
    I coulda helped you
    up until you said keep it in one piece. I assume you checked for tiny hidden screws and such?
    Thanked: 12
    I did check for little screws, and there are a bunch in there, but none that hold the glass in. Luckily the mirror is off the VX so I was able to hold it in my lap and push the glass to it's maximum adjustment. Even by doing that and shining a flashlight in there I couldn't quite see how the glass was held in. I think I see some plastic clips holding the glass to the adjustment mechanism, but I couldn't get them to budge. I'll head to a glass place first, but the mirror that I have is a busted up spare so I may just have to break the glass to get to the innards to see what's going on.
    May 2008
    99 Black
    You can just pry it off.
    It snaps on to the motor.
    How do I know?
    My wife killed my passenger mirror assembly by hitting a bird (so she says)
    She drove up with the mirror dangling by the wires.
    It was the first time she had she driven my VX since she totaled my Ebony VX.
    Spyder aka Mark Miller
  1. Full LCD Rear-View Mirror?
    By Stephen Biko in forum VX Talk...
    Last Post: 10/29/2014, 11:08 AM
  2. Tweeking the rear view mirror
    By VXjunky in forum VX Talk...
    Last Post: 02/02/2011, 08:56 AM
  3. Rear View Mirror Mount.....
    Last Post: 04/12/2010, 09:38 AM
  4. Rear View Mirror Mount
    By TechnoPope in forum VX Modifications...
    Last Post: 11/24/2004, 12:28 PM
  5. Rear view mirror mounting
    By skullcap in forum VX Troubleshooting...
    Last Post: 08/30/2003, 10:10 PM
