Results 1 to 11 of 11
Thread: turn signal problem
    turn signal problem
    all of a sudden one day my dash lights started to flash with my signals but when iturned on my headlights then my right signal worked with the dash lights flashing but my left signal stayed on no flashing but left side turn signal bulbs are a lot brighter than normal i replaced the combo switch but i still have the same problem ???
    '01 Ebony #0939
    If I had to guess (which I have to admit is sort of what I'm doing ), I'd say the fact that your left signal lights are brighter, along with the fact that they don't flash when the headlights are on, would be a good indicator (ok, sure...pun intended) of where to start looking first. Maybe one of the combination park/turn bulbs on the left side is bad?
    re turn signal problem
    thanks for trying, y33 , but last night i read on one of the threads to try disconnecting my trailer wiring module . lone and behold that was it faulty module . by reading that thread ,i saved myself hours of troubleshooting thanks again to whoever posted that thread
    Jun 2005
    01 Dragon Green VX 1286
    I have an issue with turn signals and cruise control caused by trailer wiring
    When my turn signals were jacked up, it was my trailer light adapter too. Luckly I just didn't have a good ground tho so it was an easy fix.
    '01 Ebony #0939
    Note to self: Eighty-six any future notions of using VX for towing.
  1. turn signal relay ??
    By orion in forum VX Troubleshooting...
    Last Post: 07/13/2014, 09:23 AM
  2. Turn signal on when braking??
    Last Post: 11/19/2012, 07:08 AM
  3. turn signal help
    By dsallade01 in forum VX Troubleshooting...
    Last Post: 06/28/2011, 07:44 AM
  4. Turn Signal Lens
    By SomeBeach in forum VX Talk...
    Last Post: 07/01/2009, 07:05 AM
  5. Water in turn signal.
    By tomcat837 in forum VX Troubleshooting...
    Last Post: 04/18/2004, 07:33 AM
