Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Thread: Checkers Anyone? Alpine PDX-5 Amplifier Install
  1. #16
    Dec 2006
    For the time being, I ran the amp ground to a paint-stripped/cleaned-up/dialectic-greased, front left of the four bolts that hold down the parking brake assembly.
    It may not be optimal, but it was convenient and seems to be working fine. I had as many installers telling me that a body ground was fine, as I had installers insisting that a frame ground was necessary. I didn't feel like drilling a hole through the floor metal to affix the ground to the frame. I'm capable of doing it, I just didn't feel like it, and I used the conflicting opinions to support my complacency. All installers I spoke with, though, seemed to agree that the ground wire (4 gauge, in my case), should be kept as short as possible; no more than 9"-12".
    Bren Workman
    Gretna, NE
    (C) 402-312-1992
    Jan 2008
    1999 Astral Silver 0481
    Drill ? 95% of the new set ups don't need drilling at all.All you need most of the time is scrap the paint coat at the closed bolt 'till the metal is fully exposed & attach the ground cable. For instant I removed the rear seat latches,scraped the bolt hole with a drill & sanding stone.Attached the two amps ground cables together & did the same procedure with the capacitor - cable to the front left net hook.
    Dakar was just the begining.
  3. #18
    yup, the shorter the ground cable the less noise you will get....
    secondly it isnt necessary to run it to the frame, i mean, if you wanna do it then its a good ground guaranteed but not necessary by any means...
    its a good practice to remove paint as much as possible...however, they do make star washers now that cut into the paint while tightening the ground and those make GREAT grounds....
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    They also sell multi-level braided sheathes that go around your ground wire and completely insulate it from picking up sound. It's pretty much a faraday cage design that goes around a wire. Also works if your signal wires are picking up interference. That way you can route your wires however you may need if necessary.
  1. Alpine S/C install PDF
    Last Post: 04/06/2010, 02:12 AM
  2. question to those with Alpine SC
    By ScottinMA in forum VX Troubleshooting...
    Last Post: 01/06/2010, 05:24 PM
  3. Alpine S/C users read this!!!!
    By bigpoppax2 in forum VX Modifications...
    Last Post: 07/15/2008, 12:16 PM
  4. Amplifier Ground Question...
    By biju in forum VX Talk...
    Last Post: 05/08/2006, 09:55 AM
  5. 411 on Tone & Alpine
    By xdfarrx in forum VX Talk...
    Last Post: 03/06/2005, 06:12 PM
