Results 1 to 7 of 7
Thread: shift shaft seal replaced
    Was dripping a tiny bit of what I thought was oil, up near driver's side front. About 1 teaspoon every 3 days. Took it in to auth Isuzu place- leaking "shift shaft seal". say that 3 times fast! Told me it was transmission fluid leaking, not motor oil. Anybody else have this come up? Is it common, how frequent, etc? 2001, 64k miles (no known service history). Thx!
    Nov 2008
    1999,SILVER,VEHICROSS,1270
    Hey check your power steering pump and hoes it could be comein from there i get the same drips and thats were mine drips from,yes your power steering pump use transmisson fluid.
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    Where around the drivers side front is it coming out of. I think I might have a similar problem. I was spraying something from underneath my rig on the way to Moab last year, but had no real problems after that. I do have some seepage from where my engine and trans. connect, which sounds maybe like what you have going on.
    The drip was about 7" in from the inside edge of Left front tire, and then about 4" toward the back of the car.
    Jul 2008
    1999, Astral Silver, VX, 1508
    Hi VX Kat,
    I had the same issue when I bought mine with 135k. I had pink fluid leaking from the trans.area so I was going to change all the fluids anyways including a full trans. service so I figured after I replaced both trans. gaskets, all would be good. Well it wasnt. I thought is was a faulty trans.pan aftermarket gasket so I changed to factory, no change. Finally pinpointed to to the shift shaft seal on the left side (driver's side) middle of trans on side. Took about 1 hour to replace it and the seal was cheap. Mine was failed due to brittle and aged. See my thread I started about this:
    http://www.vehicross.info/forums/showthread.php?t=14273
    Good luck!
    Larry S.
    99 Astral Silver VX (176k)
    91 Porsche 928 S4 (73k)
    Thanks Turbo, I had done a search on "shift shaft seal"...not "selector shaft seal" and didn't come up with your thread. Yeah, I too was really glad it was CHEAP! Was $106 with parts/labor out the door. I have no mechanical skills and have to rely on the auth Isuzu place, at least I'm lucky, they're close, only 20 miles.
  1. Mode Selector Shaft Seal replacement
    Last Post: 05/20/2016, 10:06 AM
  2. Steering Box Replaced
    By bartmanS4 in forum VX Talk...
    Last Post: 06/03/2015, 02:54 AM
  3. Selector Shaft Seal: Transmission Leak
    Last Post: 11/15/2014, 09:15 PM
  4. rear brakes just replaced, but car kept going!
    By dynofan in forum VX Troubleshooting...
    Last Post: 06/07/2012, 04:13 PM
  5. Anyone else have AC Fan replaced 2 x
    By mdf in forum VX Talk...
    Last Post: 11/26/2003, 06:18 PM
