Results 1 to 2 of 2
Thread: abs grinding issues
    May 2008
    abs grinding issues
    My abs light is on and I noticed the abs regulater had been removed.When I put the regullator back in to drive the car the brakes (or something) was making an aweful grinding noise.Anyone ever have a similar problem?
    Quote Originally Posted by 10spro View Post
    I don't know you would have any braking system without the regulator in place, working or not...you don't mean the relay or the fuse do you?
    The first place I'd check for a grinding noise would be brake pads, though if they were overly worn, they should have been grinding before you put the "regulator" back in...
  1. Front end grinding
    By RabidPony in forum VX Troubleshooting...
    Last Post: 05/28/2013, 03:27 PM
  2. grinding sound, like worn pads grinding on rotor but now
    Last Post: 05/15/2013, 11:45 AM
  3. Grinding help needed
    Last Post: 11/05/2012, 03:25 PM
  4. Grinding when reversed
    By circmand in forum VX Troubleshooting...
    Last Post: 08/28/2008, 05:25 PM
  5. grinding while turning
    Last Post: 02/07/2007, 07:25 PM
