Results 1 to 15 of 15
Thread: Leaking coolant from bottom of engine
    Apr 2007
    2001, Proton #1238
    Do’s it smell like coolant?
    Jun 2005
    2001,Black
    Not really, maybe a little. It obvioulsly only happens when its running and it just started yesterday.
    Apr 2007
    2001, Proton #1238
    Is the AC on?
    Aug 2007
    2001, Proton, Vx, 0000
    Mine is doing exactly the same thing...
    Before I did my cv axle boots last weekend, the truck sat for 2 weeks and everyday I would find a puddle of coolant underneath. Now that the cv axles are fixed, the leak has subsided significantly.
    I'll try posting pictures later today so you can see what the leak pattern is like (took some underneath the motor). Haven't started screwing with it yet...
    Sep 2004
    1999, Astral Silver, VX, 0938
    Also keep and eye on the coolant overflow/storage container on the drivers side inner fender well. Mark the level (a small sharpie Dot) and during routine drives compare the levels.
    Feb 2004
    '01 Ebony #0830
    this is a one-off, but freon dye is green in color too... is it coming from the area near the A/C compressor? This would only happen if you had A/C work recently and if the moon and Rylos 7 were in alignment...
    (I only bring it up because this happened, intentionally, while I was diagnosing my A/C leak)...
    SilverBullet75
    Formerly: '01 Ebony VXSTLTH
    Now: '08 Saab 9-7x Aero 6.0L
  1. Engine Oil Leaking
    By JayDallas in forum VX Troubleshooting...
    Last Post: 02/04/2015, 03:53 PM
  2. OK, time to get to the bottom of this.
    Last Post: 03/21/2014, 08:21 AM
  3. Any Y'all Soggy Bottom Boys fans?
    Last Post: 04/09/2012, 05:19 PM
  4. Engine smoking/coolant everywhere...
    By Breezy in forum VX Troubleshooting...
    Last Post: 12/07/2011, 07:51 AM
  5. cleaning bottom half of VX
    By 00BlackVX in forum General Tips...
    Last Post: 08/25/2006, 12:24 PM
